We would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Emerson TV; here some of the codes we currently have: 672, 632, 654, 764, and 537. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
SOURCE: Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Remote control code for dish network for Emerson
Your Dish remote was probably designed years before the Emerson set and may never have codes for it.
However, you can try the followng brands from the Dish code list to see if you can get some basic functionality:
Funai, Symphonic, Sylvania, Aventura, Durabrand,
ESA, Magnavox, INSIGNIA, Philips and Misakai
All of the above are manufactured by Funai - the least and lowest of the Japanese electronics firms.
