Question about Kicker KX800.2 Car Audio Amplifier
I plugged int he rca's but he the lowest sounding bass possibe
How can i fix this
    Problem Solver:
  • 14 Answers
Kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Posted on May 01, 2009
  • blood_ninja1 May 01, 2009
    also, look into bass testers before you start blasting them, this is what ruined my 10' subs. some nowdays are designed to blow the subs.
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I got a ibanez bass soundgear gio series, when i move the cable plug in to the plug hole of the bass just touching the plug head attached to the hole, makes some circuitbreaker sound like "toc"...
The jack on the guitars is a stereo type jack. The "ring" contact actually is connected to the battery and whenh the PLUG is inserted FULLY it coonects the ring contact of thee jack to the slkeeve contact of the jack which completes the circuit to turn on the battery. Hence while insertying the plug you will firsst get a snap as the tip of the plug ties to the ground of the guitar which is floating and picks up hum. Next the tip will touch the battery connection and get a snap. Finally when fully inserted both the battery is connected as well as the audio.
SOME guitars, especially those with tuners built inj will try tio fire up when the tip (audio) touches the battery cinnection. This may cycle and create the repetitive sound as it tries to start.
Feb 20, 2011 | Ibanez Gsr100 Electric Bass
I play my music on low and it has bass wen i turn the radio up it starts hiting only certain bass notes the lowest dont hit hard it starts sounding weird???? i have it hooked to a audiobahn aw1206t...
sounds like you have some wires crossed. check your radio setting and make sure that the subs are only playing bass and no trebble. buy some new rcas
Mar 10, 2010 | Nitro BMW-486 Car Audio Amplifier
I have no audio on my RCA Scenium rear projection
Replace Audio output ic. Make sure you do not have sound turned off.
Sep 28, 2009 | RCA Televison & Video
Disconnected RCA plugs from 52'' RCA and now no sound even...
ont back of the set there are a set of jacks you can hook ext speakers to make sure that switch is turned to int speakers
Nov 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Still no sub woofer output
SET THE CROSSOVER TO "L.P.F."POSITION AND SELECT THE LOWEST FREQUENCY AS THE CROSSOVER POINT.
[AN AMPLIFIER IS SUPPOSED TO "AMPLIFY"(TO INCREASE)ANY OUTPUT.]
TRY CHANGING THE POLARITY OF WIRES FROM AMPLIFIER TO SPEAKERS /SUBWOOFER.{it leads to cancellation of bass output.}
if u still have doubt contact me again.
May 26, 2008 | Alpine CDE-7856 CD Player
No sound on my RCA 27F650T
Yea I had that problem one day as well.. all you got to do is go into the menu settings and check the box for the Int speakers... that should do it
Apr 06, 2008 | RCA 27F650T 27" TV
Soung prob
Tune the gain on your amplifier powering the sub. Turn the Bass Gain on the amp all the way down and crank up your system to as loud as you can stand. Adjust the bass Gain until the Speaker begins to distort, then back off a little bit. This way you can crank it up and not get Bass Distortion early.
Nov 28, 2007 | Ultra Linear UL-1600M Car Audio Amplifier
Weird sound
get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If you get Boom then the RCA grounds in your head unit are blown and only a repair shop can fix that. Also double check all grounds making sure they are solit with the proper gauge wire. Under the rear seat belt bolts is a prime connection point. Check with different RCA's
Jun 15, 2007 | Solid Audio F11D 1-Channel Amplifier Car...
PLEASE HELP!!!
The Amp stays on because you have a constant 12V to the Remote.
If your stereo remote is no longer working then run a wire from a 12 volt source that turns on and off with your ignition something like your radio fuse in the vehicle fuse box.
As far as the Bass Knob if it is connected properly and still not working check the line for wire kinks or cuts that may have happened during installation if you cant find any problems you can get a universal bass knob that plugs via your RCA cables for under 20 bucks.
Hope this gives u some ideas.
May 05, 2007 | Pyle PLA2480 Car Audio Amplifier
Kicker KX800.2 Car Audio Amplifier Logo
159 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
