Dvd recording failure
My dvd no longer records. after cleaning it several times with no success I took it apart to see if something looked wrong. One part had a burn mark. The unit # is n78fbcun. The part that is burned has a number be7a00f0106. do you know if that part can be replaced? The price to replace the entire unit is more than I paid for the whole dvd/vcr. If you have any information I could really use the help.
  • CoolUl007 Jul 18, 2008
    I get the not a writeable disk message after receiving an error during a recording of a dvd. It seems to be a heat problem as this has happened before and when I let it cool down for a while all was well until it happened again, now. This is the greatest thing since sliced bread when it works, I love it, but now it's frustrating.
  • brister327 Jan 06, 2009
    I program the unit to record a tv program to dvd. After I hit the timer recod button, the unit "sleeps" with the red timer symbol but the "dvd" indicator blinks and no recording take occurs. ???
SOURCE: DVD Recorder Does Not Record
It took about 45 minutes, without a manual. Carefully disconnecting all cables and marking them so the would go back in the right place later. Carefully Disassembling the unit, removing the cover - 6 screws, noting all screws and where they came from, pulling the front panel using the plastic tabs, removing the top front edge cover - two screws, removing the disk assembly - 4 screws, pulling the two thin leads so I could pull the entire assembly out. Removing the back plastic cover from the DVD assembly and identifying the Optical Disc Lense. Spraying some LENSE CLEANER on the same cloth that I clean my glasses with, and carefully wiping across - gentle stroke in same direction, then opposite direction - a few times. Spray lense cleaner on the cloth not on the lense. Reassemble. Reverse order of above. Works great now. BEST OF LUCK....Or you can find almost any DVD repair facility. This is not a unique process. Robert
Posted on Jul 01, 2007
WOW this system has a lot of problems. I am having the same exact problem. At first it quit recording/dubbing on ALL the DVD-R disks, except for Sony. It quit.....then I used a DVD cleaning disk.....then it I keep getting the same recording error: "Cannot record on this disk" E4 54037380. Now the disks I have used up to this point were 1x-16x, so should I try a lower speed or is this unit a lost cause? And yea, I tried their 800 number too, and that was a waste of time. I haven't even had this unit a year yet. Any help on this would be great.
Posted on Aug 24, 2007
if yoy dont hav firm ware up date you cant fix the machine. the machine if working will on work on 4x. like i said if the machine is not working you maybe able to fix it with the firm ware up date that lets it record on 8x only, now if some of the people out ther has the firm wade update disk, they could shareit with all the people who dont, i had one but its been 2 years sence i used it, i will look for it and make it available for all
Posted on Sep 14, 2007
Yes, I agree. Dust on the lense will create this error as it did on mine. However, to save you a lot of tech fees or difficulty in dismantling the machine, just buy a can of AIR or Duster, etc. Open the DVD slide and "unplug" the unit from the wall. This will leave the door open. Lightly push the carrier back about halfway. Use a flashlight to look into the DVD and find the center area. Place the plastic tube on the air can in this area and blow it clean. Don't scrape or touch any of the mechanisms inside for safety. Plug it in and it should work if it is dust. This of course does mean that it will likely do it again and could use a 'good' cleaning as suggested above. But it is an easy quick fix. And if you are like me, I won't use it again for another six months.
Posted on Oct 01, 2008
  • 1179 Answers
SOURCE: Cannot play DVD's I burn at home on my PC.
The older dvd players may not be compatible with dvd-r disks. The newer ones usually will read all dvd formats. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 08, 2009
My toshiba dr4su will no longer record on dvd-rw discs nor will it format a blank or prerecorded dvd-rw.Ihave used this recorder successfully for a couple of years. It will play back dvd-rw. When I attempt...
If its an older recorder it could be the usual problem of a greasy center-disc =
95% OF THE TIMES I could fix a problem like this was by cleaning with rubbing alcohol the rubber ring on the little rotating disc in the center of the drive mechanism. !!!! Because users always stick their index finger into the hole of all the CD'S for inserting a disc into the tray that a tiny amount of grease gets deposited onto the little rotation disc which touches the center of any inserted disc at about half an inch from its center hole. (underneath) When its greasy the discs slide and the inserted discs speed stays uneven and slow.
You must open the drivebox ( after unplugging the power-cable) to see and clean it.
Be careful to not look at it with power "on" because the laser will make you go blind (danger!!!!!!!
I heavily use a Toshiba DVD recorder since 12 years and it is my most reliable and most versatile recorder, while my brand new Sony recorder lasted only 2 years - Others as well had problems with finalizing etc. but in general the cleaning of the little center-disc that pushes from underneath against an inserted DVD to make it spin helps the most.
Oct 26, 2011 | Toshiba DR4 DVD Recorder
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
My DMR-E80H will no longer record onto blank DVDs
One solution is to clean the laser lens. Try using one of those lens cleaning CDs.
Also, sometimes the DVD may slip on the spindle, which may cause reading errors. Spindle cleaning usually involves taking the machine apart.
Oct 04, 2009 | Panasonic DMR-E80H DVD Recorder
Videos are no longer showing on mini dvd in camcorder.
please try to play the DVD disk in a DVD player. I dont think that the video was wiped , but i think the camera has a defect in the playback software.
Sep 14, 2009 | Canon DC310 DVD Camcorder
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
You could not format the disc due to error detection, whats wrong
You can get this if you´re using RAM-discs previously recorded/formatted on a different recorder. Clean the disc REALLY WELL and try inserting several times, it may pass.
Jan 06, 2009 | Samsung DVDR120 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Doesn't hold the current date when turned off
There is a battery on the motherboard, next to the power supply connector, which may be bad or not connected securely.  That's the first place I'd look, although it should produce other symptoms, especially inability to 'remember' other setting, such as channel memory.
Sep 19, 2007 | Cyberhome DVR 1600 DVD Recorder
My dvd player blinks
Try cleanning the lens in the unit with dvd cd cleanner which can be bought in any office surplus store make sure its for dvd there are two types cd and combo dvd?cd i recomond staples office supplies it is only 10 dollars cad
May 17, 2007 | Cyberhome DVR 1600 DVD Recorder
Playback stops after 45 secs
my advise is that you need to take that set to qualified techn for repairs.
Jan 20, 2007 | Sony RDR-GX3 DVD Recorder
Open Questions:
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
