HP Officejet 7210 All-In-One InkJet Printer Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carraige Jam - HP Officejet 7210 All-In-One InkJet Printer
Anonymous
Level 3:
Guru:
  • Master 731 Answers
  • Posted on Dec 04, 2010
Anonymous
Master
Level 3:
Guru:
Answers
731
Questions
Helped
328716
Points
2071
Click here to get the detailed instruction on fixing the Carriage jam issue.
Regards
Riztech
Carriage Jam
Carraige rod is the rod that holds the cartridges and moves while printing on the paper and spreads ink on the paper and if this rod is jammed it is known as carraige jam.
Please follow the below steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423360&cc=us&lc=en&dlc=en&product=3204464
Please open this link and follow the steps.
If still the issue persists, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Thanks Bye.
Please take care and KEEP SMILING.
1helpful
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
I get a carraige jam. It asks me to remove paper,
Sounds like it needs serious servicing. You can look at having it fixed but it may just as well be worth it to replace the machine.
Help hp psc 1610 all in one printer carraige jam
Try this website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
A jam message that wont go away
Hello jmcmeeking
Open your printer like you are going to replace the ink, re- install ink cartridges close it up.
If that does not work, then open the printer ink department push the ink carriage all the way to the right it might be it can’t find the home position sensor. Turn it off and then on.
Good Luck
CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Carraige jam
If you can move the cartridge carrier, move it all the way to the left, turn the printer off and then on again.
Your printer may not be parking the cartridge completely so check the area that the cartridge rests over when parked for a sponge or wiper that is out of place.
I've pulled broken light bulbs, paper clips among the many things that can cause the cartridge from parking in the rest stop.
Regards,
Worldvet
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
k24674
Grand Canyon Tech
Grand Canyon Tech
