Technika Ardo SA 1000 User Manual
I am after a User Manual for my Technika Ardo SA 1000 Fron t Loading Washing Machine.
Are you able to HELP me?
Kind Regards
Shelley Da Costa
  • alberthall Oct 11, 2008
    Need User Manual for Technika Ardo SA1000 Front Loading Washing Machine,Please.
  • speedwj Feb 27, 2009
    Need instruction manual, and ph no of a technica service agent in Melbourne Australia for a Technica Ardo SA 1000 front load washing machine.
5 Suggested Answers
  • 1294 Answers
SOURCE: ARDO TOP LOADER WASHING MACHINE
Click on "washing machines" (below FIXYA)on this website, go to Ardo (if available) type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you hav your manual on line.
And rate me pl.............. if helped
Posted on Jan 03, 2008
  • 223 Answers
SOURCE: LOOKING FOR USER MANUAL FOR WFT2400 BOSCH FRONT LOADING WASHING MACHINE
Try this website: www.bshappliancecare.com and I think you might find what you are looking for. Good luck.
Posted on Sep 26, 2008
SOURCE: Bosch Model WFB 1605 washing Machine
Hi
I have a user manual - swedish, Suomi, Norwidian and danish
Posted on Jan 21, 2010
SOURCE: ARDO washing machine
i should set my machine for washing program manually or is it automatic?
Posted on Apr 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Manual for a Fagor Washing Machine FUS 3611 IT
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
Hi, where can i get a manual for a washer machine type ardo wd 800. thank you
go on line and put in your model number ,you may be able to print it out
Nov 09, 2013 | Washing Machines
Hi there! i need a manaul to ardo flo126e washing machine. the problem is i cannot find it anywhere on internet or ardo site. plese help. Best Regards, Filip
I've just followed my own FixYa advice on obtaining various manuals and have found this for you ;-0)
http://www.washermachine-manuals.co.cc/washers/manufacturers/pos/ardo_flo_126_e.html
(If!) this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 27, 2011 | Washing Machines
I bought ARDO Model-XPB100-8911S Washing Machine 12kg on 26 March, 2011 every thing packed inside but after taking to my home & preparing place to use I couldn't find users manual. What shall I...
Go back to the dealer and demand your manual. You have a right to it and you paid for it. Stand your ground and do not accept any excuses.
Apr 19, 2011 | Washing Machines
I want ARDO Washing Machine 12kg Users Manual. I bought on 26 March, 2011. Unfortunately the Machine has no any Manual that had been attached with it. So I am in problem to begin with. Please let me get...
Hi from retired Englishman in SW France!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck ;-0)
John C.
Mar 29, 2011 | Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
Jul 06, 2008 | Washing Machines
Jan 03, 2008 | Washing Machines
Open Questions:
Kenmore Elite HE4T Washing Machine Diagnostic Test Didn't complete and clothes aren't spun as dry as in the past I have a Kenmore Elite HE4T washing machine and I noticed that recently it isn't getting all of the clothes completely dry from the final spin cycle. Thus, the dryer has to run through two cycles to get the clothes dry. I did a bunch of research and made sure there weren't any kinks or blockages in the drain lines; and opened up the bottom of the washer and cleaned out the drain cleanout. I found a few pennies, but everything seemed to be working ok. I ran a load and had the bottom open so that I could make sure the motor, drain and belt were all working properly. The drain does get the water out of the washer, so the clothes aren't sitting in water, they just don't seem to be spun as fast or as long as they used to. I always put it on the "extra high" spin setting no matter which type of load I run. So, I found a way to run the diagnostic test on the washer and it went through C0-C5 (the agitation step) and all worked great, until it wouldn't come out of C5 after at least 10 minutes and go thru C6-C8. I had to cancel the diagnostic test and hit the "drain and spin" button to get all of the water back out of the washer. BTW, the "drain and spin" seems to get the clothes a bit drier than when I have it run through the "normal" cycle with the "extra high" spin. If anyone has any other thoughts, I would really appreciate it. This unit is in a small space with the dryer attached so to take it out and do repairs is a pretty big hassle. It has had a new control board and two new fill valves in the 10+ years that I have owned it. Questions I have: 1.should I remove the entire drain pump to make sure there isn't anything lodged in it? 2. could it be the belt slipping slightly and keeping the spin from reaching its 1200 RPMs? 3. Anything else I may be missing???
Jan 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
357 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
