Question about Pioneer DEH-P3900MP CD Player
After market radio connected to a 2003 Chevy Trailblazer
My after market radio is connected with the wire hardness for GM, but it is not connect so that it turns of with the car's ignition switch. The radios (red) wire is connected directly to the battery which cause the radio to be constantly on. How can I fix this so that it shuts off along with the igniton switch?
    Brigadier General:
  • 6,966 Answers
The recommended wiring is that the yellow wire (from the Pioneer DEH-P3900MP) be connected to an "Always ON" B+12 such as the battery's positive terminal. Additionally, the red wire should be connected to a switched/accessory +12 such as the ACC terminal of the ignition switch. Wiring it this way would switch off the radio when key is likewise off.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 27, 2008
Installing a Dual XDVD276 radio in a 2005 Chevy Impala without the factory end of the wiring harness.
You will need to splice the wires as it will be hard to find the right connector to attach to the harness wires. Use the wiring diagram for the car (get it at Alldatadiy.com) and the one that came with the Dual unit to figure out which wires connect to each other.
Nov 30, 2017 | 2005 Chevrolet Impala
Reduce power light on has no throttle and keeps giving throttle accuator cdes
2003 Silverado 2500HD REDUCED ENGINE POWER - Discussion on Topix
www.topix.com > Top Stories
Dec 28, 2009 - 20 posts - ‎12 authors I have replaced the throttle body, had the wires re-connected and .... The gauges all went wild and reduced engine power displayed on the dash. I looked it .... The truck just went to idle for no reason and it keeps happening. 2003 Chevy Trailblazer-CHECK ENGINE LIGHT AND ...
Dec 23, 2011
Reduced Engine Power message
Jul 29, 2008
2003 Chevrolet Silverado - Reduced Engine Power
Nov 3, 2007
Trailblazer - Reducted Engine Power
Aug 3, 2006
More results from www.topix.com
Reduced Engine Power Message Displayed on GM Vehicles
www.underhoodservice.com/tech-tip-reduced-engine-power-message-dis...
Dec 10, 2012 - Tech Tip: Reduced Engine Power Message Displayed on GM Vehicles ... Model year 2008-'10 vehicles must have the engine control module (ECM) reprogrammed ... Do not drop the electronic throttle control components.
Oct 28, 2015 | Cars & Trucks
I PUT AN AFTERMARKET RADIO WONT POWER UP.
If your Trailblazer does not have rear seat audio, check the 15A RADIO FUSE in the I/P fuse panel. If your Trailblazer has rear seat audio, check 15A RADIO FUSE 41 and 10A HVAC B FUSE 36 in the rear fuse block. You may have to use a different adapter to get the radio to work.
Dec 22, 2014 | Cars & Trucks
What's the Motorola box under my back seat Chevy trailblazer 02 also I'm hooking a amp to battery where do I connect the amp turn on wire I guess it be remote wire
The motorolla box may be remnants of an old disk changer for the stereo. With an amp your power wire goes into the positive wire that goes to your battery, your ground wire will be connected to some bare metal close to wherever you decide to install the amp, and the blue remote wire will be connected to the remote wire that in on the wiring harness of your aftermarket radio ( I'm sure your not installing an amp with your stock radio). Good luck I hope this helps
Oct 05, 2014 | 2002 Chevrolet TrailBlazer
My window switch for 2004 chevy trailblazer quit working
It is the motor its self going bad. Which is actually better than the relay. Easier fix and easier to find part. It is a common problem in GM vehicles.
Aug 05, 2014 | 1A Auto Parts 2004 Chevy Trailblazer EXT...
How to run a radio power wire to vehicle accessory wire
use the same power wire that ran the old stereo.
Jul 31, 2014 | 2003 Chevrolet TrailBlazer
No power going to the trailer connection on 2003 Chevy suburban
check fuses also is it manufacture installed or after market installed. if manufacture installed check connections behind the connector. if after market installed check where they spliced wires into the tail light wires behind bumper and any where else that wires could be connected do you have tail lights and brake lights on the suburban send email to allactionmaintenance@gmail.com
Apr 02, 2013 | 2003 Chevrolet Suburban 1500
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
I have a 2007 chevy trailblazer with a factory touch screen navigation and xm radio. I have contacted XM for their subscription and they have on several times tried to reset or resend the signal to my...
All i can really suggest is let GM check it out if they want to replace it, i would look into replacing it with a upgraded after market unit to fit in its spot. probably cheaper than dealer will charge.
Nov 27, 2008 | Car Audio & Video
Radio Console wireing
A decent auto repair manual for your 2003 Chevy TrailBlazer (such as Chilton's, Clymers, Haynes, etc...) with a complete wiring diagram should give you the color codes for the factory speaker wiring. You can probably find and copy the pages you need at your local Public Library too.
Good Luck.
Feb 24, 2008 | Car Audio & Video
Pioneer DEH-P3900MP CD Player Logo
196 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
