Question about Dual XDVD8181 Car Video Player
No picture everything works but seeing the picture on the screen
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 23, 2008
How do I fix my Westinghouse Digital flat screen TV; when turned on using remote everything works, There is no picture
then every thing does not work . as the picture is possibly the most important thing .. shine a flash light on the screen and see if you see an image .if so you need to take it to a shop and have it repaired .
Nov 18, 2015 | Westinghouse Televison & Video
My picture works but everything is a blue color, but it works
Have you set the format to PAL, NTSC or whatever the standard the camera is.
Feb 09, 2010 | Sanyo DS27510 27" TV
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
White screen
Maybe a change in batteries could help
Apr 27, 2009 | Sanyo Xacti VPC-T700 Digital Camera
WHITE SCREEN
The live-view sensor could be defective or broken.
Also, the camera has a viewfinder.
Apr 10, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Everything works but the picture; even on screen programming
try pluging cable wire directly to the tv to see if you get a picture you may have shorted out the rca connection may need to be repaired good luck.....
Jan 11, 2009 | Emerson EWC1301 Combo
My screen is showing like multicolors & it still takes pics
Hi There, If your screen still lights up, sounds like the LCD Panel is cracked.
Dec 11, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Canon A520 Everything works, except the button you take pictures with. It wont work.
I need more information about what symptoms you are experiencing. I am going to guess that your shutter is stuck closed. This would cause a blank image to show on the view screen and your captured pictures. The regular icons and text would still display normally. Is this what you are seeing? If not please explain further what is happening and I will respond again with more information. David Millier Advance Camera Repair
Mar 12, 2007 | Canon PowerShot A520 Digital Camera
Dual XDVD8181 Car Video Player Logo
108 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
