Question about Akai LCT2715 27 in. LCD Television
Akai tv wont turn on
I have an akai lcd tv. when i plug it in the little indicator light beging rapidly blinking orange and non of the buttons on the tv or remote do anything. Please Help
  • poolbar Jul 22, 2008
    tv will not turn on only get orange flashing light.......
    Problem Solver:
  • 4 Answers
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
  • lizardroot Jun 06, 2011
    This is a great solution! I got an AKAI TV on the side of the road and the light blinks orange and the speakers pop really loudly. My TV only worked once (the first day I found it).
    Did you really only pay 6$ for your repair???
    Please send any additional info....
    I'd REALLY like it if you would tell me step-by-step how you repaired your TV!!
    If you did that, you'd be a life saver!!!!
    Thanks!
  • 30 Answers
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Posted on Jul 04, 2008
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
Jvc rear projection tv turns on and showsthe picture for ablessing second the shutsrecord off andmy blue and orange lights blinking together rapidly
Lights indicate shutdown--A model number would allow me (it is not indicated on this question) to research it if I do not already know the issue and answer.
To add information or a further question press the "make a comment button" on this page.
Mar 25, 2012 | JVC Televison & Video
Remote code wanted
Hello
Three digit universal remote code for Akai TV are: 002/ 0030.
Four digit universal remote codes for Akai TV are: 0105 0002 0077 0254
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jul 01, 2011 | Akai LCT3701AD 37 in. LCD Television
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
MY 4YEARS AKAI LCD TV IS BLINKING ORANGE LIGHT BUT
Read the info from the link below to troubleshoot the failure with your LCD. Try not for force the LCD to work because for the time being it might only need the capacitors listed in the link but if the lights is blinking red, then the failure is a bit more complex to repair.
http://www.fixya.com/support/t3771079-lct2701td_t_v_will_not_turn_only
Feb 28, 2010 | Akai LCT2701TD Television
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
Tv wont turn on
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3785TA POWER SUPPLY BOARD MLT386X
Oct 02, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
188 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
