Question about HP DeskJet 820Cse Printer
HP DeskJet 820Cse printer problem
Printer consistently fails to feed paper from input tray; has to be hand fed.  Is this a problem with weak or smooth rollers, or thin paper?  I am using 20 lb. Office Depot multipurpose paper.
  • Anonymous Oct 25, 2008
    Any 1800- # I can call for repiar?
    New Friend:
Use a flat screwdriver to roughen up the piece of cork that is at the back of your paper tray/feeder.
Posted on Mar 30, 2013
  • HP Master
  • 2,794 Answers
You could try cleaning the rollers with some soap and water. Make sure the power is off first.
Posted on Jun 27, 2008
Printer does not pick up paper to print.
The rollers may be dirty and slipping. I just fixed this problem on my old HP 820Cse by cleaning the three rollers with rubbing alcohol (99% isopropyl alcohol) as follows:
1) Remove the paper tray. The release lever is under the tray.
2) Saturate a small 4-layer pad of paper towel with the alcohol.
3) Try to print something. The rollers will turn. While they turn, hold the alcohol-soaked pad firmly against one roller.
4) Repeat 5-10 times for each roller until no more black stuff comes off. (Push the button next to the printer's amber light to repeat the print cycle.)
5) Slide the tray back in. You're good to go!
--(posted 9/13/11 by Donjo)
Feb 17, 2011 | HP DeskJet 820Cse Printer
Printer tried to take half of the stack of paper and jammed up. Can't get the paper unstuck.
Unlatch and pull out the paper tray. Try pulling out the sheets in the middle of the "half stack" first. You should have less friction there. While you have the paper tray out, examine the rectangular cork paper separator strip on the right-hand side of the back corner. If it's worn or missing, that would explain how the jam got started.
Dec 06, 2010 | HP DeskJet 820Cse Printer
Seems like the rubber feeder wheels won't pick-up the paper to feed... what can I do to get my HP 870cse to feed?
Usually that is caused by foreign object restricting the operation.
take the feeding tray out and open the top and examine it for foreign objects. It may need a little cleaning.
Nov 05, 2009 | HP Deskjet 870cse Printer
PAPER WILL NOT FEED
hi there !
you may do the steps below:
-Ensure the Paper Tray is Not Overfilled
-Adjust the Printer Paper Guides
-Locate and Remove Any Obstructions Inside the Printer and Input Tray
-Determine if Multiple Sheets Are Fed at Once From the Paper Tray or Automatic Document Feeder (ADF).
-Verify the Print Media Installed Is Compatible With the Printer
-Clean the ADF Paper Feed Roller
-Reseat the Dell Printer Power Adapter
-Try a Different Type of Print Media
*If all else fails
-Replace the Dell Printer
cheers!
Oct 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
HP Deskjet 820 Cse will not load paper
I have fixed this problem by cleaning the three large paper feed rollers. You can get at them by removing the paper tray.
HP told me many years ago that, over time, additives used in the rubber material that makes up the rollers moves to the surface and makes the roller slippery so that it does not drag the paper forward.
I clean mine by rubbing the surface with a rag soaked in methylated spirits (a type of denatured alcohol). A fiddle of a task but it works.
Regards
Wizzer of Colour4Free
Mar 23, 2009 | HP DeskJet 820Cse Printer
Deskjet 820cse wont feed paper
try using lemon juice n cleaning the rollers at the bottom probably slipping on paper
actionman
Mar 01, 2009 | HP DeskJet 820Cse Printer
Paper feed
Make sure you fan the paper before putting it in. 20 sheets is usually about right for these printers.
If you put labels in the printer. Only put a few sheet in at a time and put paper stock below them.
May 22, 2008 | HP DeskJet 820Cse Printer
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
HP DeskJet 820Cse Printer Logo
213 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
