Question about AT&T Blackberry Curve 8300 Smartphone
Camera Hi, My bb curve camera, just quit working..the screen is either green, brown's or purples..have checked all the settings and have no idea what to do. In the left corner of the screen when you were asked to take another picture..delete and so on...that has disappeared.. Please help Thank You Shirley
  • 2,359 Answers
This is the initial sign of the camera coming loose from the socket on the main board.
If it still in warranty then send it out for repair.
If it's out of the warranty then you can put a foam or plastic spacer to under the battery cover.
Just like the battery foam pad under the battery.
Place few tab of supporting material under the battery cover. Make sure they does not cover the lense or the flash.
Next time the camera give you the error message again or ghost like image.
Take the battery out and press the camera and flash area firmly until you hear a soft plastic snap sound.
Once the camera contacts snap back in place then your are back in business.
Posted on Sep 19, 2009
I have a Q-SEE security camera, that received water damage from a rain storm. The ethernet connector had to be removed and I am interested in hardwiring the camera to my CAT5e cable. The QCN8004B camera...
I had the same problem and had to rewire the ethernet jack on my Q-See camera QCN7001B.
The wiring I found was different than on the Q-See website.
Pin 1 is brown
Pin 2 is purple
Pin 3 is orange
Pin 4 is yellow
Pin 5 is blank
Pin 6 is blue
Pin 7 is blank
Pin 8 is grey
Jeff
Apr 06, 2014 | Security Labs Home Security
Screen black or with lines/check
The camera has a system control board problem, this controls all the key operations of the camera. Unfortuneately cost to repair would not warrant the expence to persue the matter.
Mar 04, 2012 | Ricoh Caplio R6 Digital Camera
I have a toshiba laptop with a built in web cam when ever i go to it, it only show up purple and green. How can I change the color so that I can see the real picture?
Hello there,
If that purple and green that is showing on your camera is the screen cover, then we can disable that. Go to camera settings/effects/disable the screen cover. If not then go to device manager/imaging device/and uninstall the chicony driver but do not delete, then restart the NB, then try to start the camera.
Hope it works.
Mar 12, 2011 | Toshiba Satellite P305D-S8828 Notebook PC
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
Looking at the screen and through the view finder, all looks green and purple? How can I fix this, I changed a setting somehow
I just tried changing the film type settings on my S5000. (the blue button, standard,chr, b/w) None of those changed the colors to purple and green. It may be that the camera has a failing CCD. It would be a rather expensive repair and not a DIY.
Feb 01, 2010 | Fuji FinePix S5000 Digital Camera
Needinfo on what wire does what on the Kenwood Excelon DDX7015, on the main harness and the little 3 wire harness near the center,
yellow-constant
red-accessory
if there is a light green,pink,or brown one is is us for brake ,
purple/white -camera or green/white
green/black-left rear- spk-
solid/green-left rear-spk+
purple/black-right rear-spk-
solid/purple right rear spk+
gray/black-right front spk-
solid/gray-right front spk+
white/black-left-front spk-
solid/white-left front spk+
brown or orange if any phone mute
black -ground
pink/white or purple/white or green/white-reverse camera''
Jul 10, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Blackberry Curve 8310 LCD Screen won't turn on
You can find Video Disassembly Instructions at
www.fonlogix.us
They have New LCD's for the cheapest price.
Here is a Coupon code for 10% off at their site
Code: Fixya10
Sep 01, 2008 | RIM BlackBerry Curve 8310 Smartphone
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Streaks of red and green flashing across screen when turned on.
Well I guess you mean purchased December 2006 yes? In which case you could be in luck- return it to the seller as defective - which it is. If older- contact the maker website - this is a defective CCD There has been a recall on certain brands of camera that use the same CCD which is failing early.
Sep 30, 2007 | Kyocera Finecam M410R Digital Camera
AT&T Blackberry Curve 8300 Smartphone Logo
91 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
