Question about APC Smart-UPS 1000VA UPS System
Aboyt ups APC 1000
Dear sir
am working in organization the problem is the ups stop i dont know why , i checked it by giving power but it didn't give light, sound ....everything is stoped so what can i do to fix the problem.
thanx.
    Scholar:
  • 64 Answers
If it is older then 3 years old, your batteries could have depeted or you had a black out and drained your batteries beyound safety level. If you replace the batteries, it should come back alive. If it does not come back on, your inverter is dead. It is a 50/50 chance that it will come back alive. May I suggest you take it to a battery store, and allow them to give it a try. It might save you money then holding two good batteries, and one bad UPS.
Posted on Sep 08, 2009
Cannot connect Samsung c3050 using Data cable USB APC10 to win 7
Well your hardware was working on windows Xp and it seems they didn't issue a driver for Vista or win 7.
You can try to e-mail APC directly for support. Furthemore they stopp the support for the encryption software Omnipass, you will have to see directly with Softex for the software's support.
If APC can give you a Vista driver, it might work, but otherwise you can try to run your APC installation CD on Windows XP compatibility mode see here for the details.
If none of the above works, well your hardware is now obsolete on win 7.
Hope this helps
May 18, 2011 | APC Biopod Fingerprint Reader
Hello sir, I don't actually know how to charge my apc cs 650... and And when the power is out, so does my computer.. low battery.. I just need a simple answer about this.. is it not charging? or do i need...
If you connect the control cable to a PC and install the PowerChute Personal Edition V3.0.2 f software you should be able to see if it is charging and what the percentage of charge held in the battery is.
On the CS 650 the lowest power connection is the surge only powerpoint.
To give the battery a full charge or to test it you can connect it to a car battery trickle charger, as it is a 12 volt battery, rthis will at least mean you can check that it holds a charge in the first place.
Dec 23, 2010 | APC APS BackUPS CS 650VA 400W 230V DB9...
My ups does not give enough back up and the others are not powering
It is usually a battery problem.It is not charging anymore.The battery is the power source for your UPS once the AC source is cut off.Open the unit and there you could locate the battery enclosed inside the UPS box unit.Replace it with the same type and size of battery, observe polarity where the red is (+) positive and black is negative (-).Depending on what the manufacturer used for the color coding but still see where the Positive and Negative wires are connected to.But before you open the unit remember to unplug the unit from the power outlet.
Nov 06, 2010 | APC Smart-UPS 1000VA UPS System
I have a UPS 1000 VA with 12 V X 2 Battery, Problems: when we on ups input 200 V without load, it gives output 210 V. when load it gives 230 V on electricity. When Electricity cut off it gives 250 V. When...
arif qc, Are you using a DMM that is or will make "true RMS" measurements or is it an "average responding" type of voltmeter? Is this APC ups designed for 120 vac input/output or is this unit a 220 vac input/output type? Use only a "TRUE RMS" type DMM to make your measurements!!! I believe if you visit Tripp-Lite site, you will find a tutorial video clip of why you should use a true-rms meter to make measurements of output voltages. 12fixlouie
Sep 07, 2010 | APC Smart-UPS 1000VA UPS System
Overload light lights and unit beeps. It is not pluged into power and nothing is pluged into the unit.
It sounds like the battery is compatible with the ups.
However, APC has excellent free phone support.
I recommend that you give them a call.
Be ready to give them the model number and serial number for your UPS.
(800) 555-2725
Please vote for my solution if it helps you solve your problem.
Sep 05, 2009 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
Apc smart ups su1000, su750i and sua700inet circuit diagram
you mean you need a circuit diagram for the following APC unit? i dont think so if you can get unless theres one MF from APC manufacturing or service center that can give it or sell it to you. beacuse as far as i am concerned it is punishable by law to sell or to give copy of all circuit diagram of APC products. Good luck
Aug 04, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
I WANT NOKIA3230 ULTRA MP3 LICENSE KEY
Your Ultra Mp3 Player
License Key : 27581
Feb 15, 2009 | Nokia 3230
After spark apc ups stopped working
just check the fuse and mosfets(the one with 3 pin ic's) and replace if necessary
recommended to handle if u r a technician with soldering and component testing knowledge.
remove the battery and re connect after 2 mins
Sep 13, 2008 | APC (BE500U-WEB) (BE500UWEB) UPS System
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
APC Smart-UPS 1000VA UPS System Logo
138 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
