Question about Samsung DLP HL-P5663W 56" TV
Samsung 50" DLP TV
We got error message on screen, "Check Number 2 Fan" then the TV shut down.
  • 1 more comment
  • irishvno Nov 13, 2008
    I have the same problem but cant find a diagram to show us where the fans are.
  • VTsironis Jan 03, 2009
    The owners manual does no show the location of the fans
  • skidevl Jan 04, 2009
    where do we go to get a new fan
  • 4,234 Answers
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Posted on Jun 27, 2008
My Samsung 50 inch DLP tv just started acting up. I have a good picture but at the bottom of the screen is a blue box that says "check the No. 1 fan". Then after about 5 minutes, the tv will shut down
I am not familiar with your Samsung 50" DLP, BUT.... The alert message implies that something is WRONG with the "No. 1 Fan." I suspect that it has QUIT WORKING altogether, and after a certain period of operation the TVs internal temperature builds up to a point where the heat becomes dangerous, either to the components, or even possibly becomes a fire hazard.
The shutting down is probably a self-protective function to prevent any more overheating which would seriously damage internal components exposed to the heat, or worse, cause a fire!!!!
Unplugging is good as it allows the system to cool down, BUT to continue use without repairing the cause of the fan failure, is dangerous!!!!
Either get your TV into a QUALIFIED REPAIR SHOP, or get a qualified PROFESSIONAL out to the TV.
IF the problem is not corrected, the TV could be irreprably damaged, or could catch on fire, neither of which is good!!!!!
Jan 10, 2015 | Samsung Televison & Video
Samsung 50 inch DLP
Most Dlp sets have a fan for cooling the bulb this should start at switch on if it doesnt bulb will not light.
Check fan is pluged in & that blades can turn freely.
Oct 11, 2007 | Samsung (LTR268W) Television
My samsung 61in. Dlp screen flashes green/blue pic is viewable but everything is the two colors, also screen will flash icon check fan #1
You have 2 problems. Problem 1 either you main board or light engine is bad and needs to be replaced. Problem 2 is exactly what your TV says. Fan#1 isn't functioning properly so a heat sencor is being actiated to shut down your set. Make sure all the fans are free of debree and spinning. If one is not spinning, make sure it has voltage going to it. This will let you know if you have a bad fan, or a bad board.
Jun 05, 2012 | Samsung 61" Slim-Depth LED DLP HDTV
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a 50" samsung
Check the Fans make sure they are not dirty ,if they are clean them,Fan2 error means something is wrong with Fan2#
Nov 02, 2010 | Samsung HL-S5086W 50" HDTV
My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Hi i have a somsung tv dlp. Shuts down as soon as
yes is one of your fans..
try to open the back of your TV and check that all of your fans are working if you see one is not. try to look at the part number.
here is a website where you can find a really good price..
its like $9.00
good luck!
Dec 27, 2009 | Samsung 50" Slim-Depth DLP HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Smasung 50 Green Screen
apparently this is caused by a surge in yr electricty supply- burns 4 or so IC's and a part called SPF- Samsung dealers can do the repairs for you but since ist power related, its not under warranty.hope this helps
Dec 11, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Nov 29, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
393 people viewed this question
Jerry Greenberg
Jerry Greenberg
