Question about Super Tutor Trigonometry (ESDTRIG) for PC
Algebra what are the angles of a triangle ABC? which satisfies equations C=3B AND C=2(A+B)
C = 3B = 2(A+B)
3/2 B = A+B
1/2B = A
C = 2 (1/2B + B)
C = 3B
**A = 1/2B
C = 3B
B = B
1/2B + 3B + B = 4 1/2 B
180/4.5B => B = 40
If B = 40, then A = 1/2B = 20 and C = 3B = 120.
**answer: A = 20 degrees, B = 40 degrees and C = 120 degrees.
Posted on Jan 10, 2009
If M is the midpoint of triangle ABC, ACB = 30degrees and BMA = 45 degrees, calculate the size of BAC in degrees.
Since M is the mid point of the triangle, the distance of M from A,B and C is equal which means AM = BM = CM.
Therefore, MAB = MBA. In triangle MAB, MAB=45 degrees.
sum of angles in a triangle = 180 deg. So, sum of angles MAB and MBA = 180 - BMA = 180 -45 = 135.
Since both MAB and MBA are equal , MAB = 135/2 = 67.5
In triangle AMC, MAC = MCA . Therefore MAC = 30/2 = 15 deg.
Therefore total BAC = MAC + MAB =82.5 deg.
May 19, 2017 | Homework
Finding the area of a triangle in the coordinate Plane
I find the easiest way to solve these is to sketch them first (I'm a visual learner;) We get a nice right-angled triangle, with the right-angle at B. The formula for the area of a triangle is 1/2 * base* height or (base * height)/2.
We can use BC or AB as the base.
If we use BC as the base, the length is 9-4 or 5. The height is 6-2 or 4.
We can now but the base and the height in the formula to figure out the area.
Good luck.
Paul
Mar 19, 2015 | Office Equipment & Supplies
Finding area of a Triangle in the Coordinate Plane
The area of a triangle is 1/2 times base times height. A sketch of the triangle in the coordinate plane will determine how easy or hard this will be to be. From the sketch, you will see that this is a right-angled triangle with B being the right-angle. This makes it easier because we can easily determine the base and the height to use in the formula.
We can chose AB or BC to be the base, while the other will be the height. If we choose the base of AB, its length is 4, the 6 - 2. The height is 9-(-4) or 13.
We can now put the length and height into the formula to calculate the area of the triangle.
Good luck.
Paul
Right Triangle ABC has vertices A (-4 2)B(-4 6) C (9 6)
Good luck.
Paul
How do I sole system of equations
To solve a system of equations, there are two algebraic ways to solve them, one is by substitution, while the other is elimination.
1) 2a + 3b + 5 = 0
2) 2a + 4b + 10 = 0
-b -5 = 0 (subtract 2 from 1)
+b-b-5 = b
-5 = b
Substitute into 1) to solve for a.
2a + 3(-5) + 5 = 0
2a -15 + 5 = 0
2a -10 = 0
2a -10 + 10 = 10
2a = 10
2 2
a=5
Substitute into 2) to check if we did it correctly.
2(5) + 4(-5) + 10 = 0
10 -20 + 10 = 0
0=0
Good luck.
Paul
Feb 10, 2015 | Office Equipment & Supplies
I need assistance understanding this algebra equation and the steps to solve it. 7+(9-5x)=5(2-x)
this is a simple algebraic equation in which we have to calculate the value of 'x' using simple operations
7+(9-5x)=5(2-x)
step 1(pen the brackets) 7+9-5x=10-5x
step 2(add 7 and 9) 16-5x=10-5x
now as 5x gets cancelled both the sides of the equal sign therefore no solution of this algebraic equation exist.
Mar 24, 2011 | MathRescue Word Problems Of Algebra Lite
1. calculation for excel spreadsheet macro for calculating the a right angle triangles hypotinuse and opposite side, angle given
Hello this is Baris,
First off all when you say hypotinuse I think it is a 90 Degree triangle. Total of the angles off a triangle is 180 degree. So it is a simple algebra question.
Hypotinuse is 90
Right angle is R
Left angle is L
Total is 180
Equation is 90+ R +L = 180
We are looking for R, so lets arrange our equation.
R= 180 - 90 - L
R= 90 - L
This is our formula for excel
Lets put it in the excel
Type in A1 "hypotinuse "
Type in A2 "Left Angle"
Type in A3 "Right Angle"
Type in B1 90
Type in B2 "whatever the value given for the left angle"
Type in B3 =90-B2
As soon as you change the value in the cell B2, B3 will change by itself. Hope this helps :)
Sep 27, 2009 | Microsoft Excel for PC
In triangle ABC, the bisector of B and C angle meet P. Through P a straight line MN is drawn parallel to BC. Prove that MN=BM+CN
Assuming M is the intersection of MN with AB, and N is the intersection of MN and AC:
Angle ACP = angle BCP (by definition)
Angle NCP = angle BCP (intersection of line with parallel lines produces equal angles)
Triangle CPN is isoceles (two equal angles), and line NP = CN
Same argument for line MP = BM
Therefore NP + MP (i.e, MN) = CN + BM
Sep 08, 2009 | Canon Office Equipment & Supplies
Computers & Internet Logo
344 people viewed this question
Top Super Tutor Computers & Internet Experts
ali_zulfikar
ali_zulfikar
cwradio73
Are you a Super Tutor Computer and Internet Expert? Answer questions, earn points and help others
