Question about Panasonic PT-44LCX65 Television
Air Filter Cleaning error message
Cleaned the entire TV, didn't find any filters but message persists and TV shuts off after a few minutes. How do you reset air filter and /or get rid of message???? Any ideas???
  • Anonymous Jul 29, 2008
    Same problem. I live 100 miles away from the closest city and cannot get anyone to fix this. Can anyone help? I am using this TV for educational purposes with a nonprofit aganecy.
    Problem Solver:
  • 12 Answers
There are indeed 2 air filters on the light engine. To clean these, it is necessary to open up the television's back lower panel, remove an electrical component, then slide out the projection unit (you must be very careful - this is over $600 to replace if you break it). The air filters are pretty easy to clean...I used gentle strokes from a soft bristle hobby paintbrush and blowing (I wouldn't recommend using a can of compressed air for this...these filters are somewhat fragile). Dust out the rest of the unit pretty good (use EXTREME caution when doing this). Then put everything back together, and then you have to go through the re-alignment procedure. You can obtain the technical service manual on the Internet...sorry, but I can't help you find it...I am not sure about the legal/copyright ramifications of distributing the manual w/o Panasonic's permission...but its out there...Google is your friend. I would NOT attempt this repair without this manual...it contains crucial diagrams, and "gotcha" warnings (like what order to tighten screws for example). This isn't a hard repair if you just take the time to prepare, move slowly and methodically, and don't be in a rush. Good Luck!
Posted on Sep 22, 2008
No no no no u do not slide out the projection unit u simply pop off the front of the TV directly in the middle there is a panel with two screws then vac out the entire spot becareful do not blow dust around on the projection then take a can of air duster blow underneath the unit u should seee little clouds of dust. Make sure u vac out the thin foam cover with the grill then ur tv should be working great Good Luck hope i could be some help !
Posted on Jan 30, 2009
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Air filter cleaning needed message comes on and need to clean and shuts down after 1 minute. what do i do? where is the filter i took the back off and no filter. i blew it all out. anything else?
There is a side panel where the Lamp is located and held on by a screw or two.
Open that compartment and vacuum out all dust. Also any fans should also be cleaned.
Jul 29, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Auto power down
have you tried cleaning the air filter?
Mar 26, 2008 | Mitsubishi WD-65731 65" HDTV
Panasonic PT-44LCX65 Television Logo
851 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
