Question about HP OfficeJet 6210 All-In-One InkJet Printer
Vertical Line on scan and copy
I too am facing this problem on my officejet 6208 printer where a think vertical line about half inch thick shows up on all scanned and copied docs. Even scan preview has this line.
Did u find a way to resolve this? Appreciate if you can forward the fix to me at bipintoro@yahoo.com
Bipin
  • temika Jul 15, 2008
    I have the same problem, but it is with the 5610. The line is not as big as before, but it is present.
    Novelist:
  • 106 Answers
I would like you to exactly follow the steps in order for you to resolve your issue.
JUST DOUBLE CLICK HERE ==>> DOCUMENT
Please update me regarding the result.
Thank you so much.
adonscott
Posted on Jul 17, 2008
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
A thick black vertical line appears whenever i
you have a problem in your scanner assembly, clean or replace it
Apr 03, 2010 | HP Officejet 4355 All-In-One InkJet...
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
Blue line vertical on all color copy and scans...help
try this web page, copy and paste the link into address bar. search facilty at top
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+7410+All-in-One&pid=391195&productBigSeriesOid=391192&spid=391194&opname=HP+Officejet+7410+All-in-One&contextual_lname=&pname_desc=HP+Officejet+7410+All-in-One+Printer%2FFax%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Officejet+7410+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=-1&method=prodFinder&qry=blue+vertical+line&Submit.x=0&Submit.y=0&Submit=go
Nov 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
