Question about Sega Genesis 2 Console
With my sega megadrive11 system when tuned in only sound comes no picture
  • 52 Answers
Hi Wisebear,
First It maybe your TV not tuning in properly.
to try this go to your TVs Tuning menu and select manual tuning and fine tune around the sound and see if this helps...
second it may be the lead (worn wire) and not enough signal getting through, so you need a new cable
you may just want to upgrade to a scart lead
www.retro-cache.com
sells the scart lead for Megadrive 2's and soon will be doing Megadrives 1's as well, both RGB.
Posted on Jul 08, 2008
Ive got a sega megadrive and i want to get it working on my lcd tv , Can i ??
yup lcd tv's today still have cable inputs. so u should be able to.
question u can answer for urself. whats the point of a sega megadrive. like there is only 1 game preloaded (sonic) and it doesn't even have sound.
the only thing i liked about the system over the other sega is that it has headphone jacks.
Oct 25, 2010 | Sega Megadrive Black Console
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Good luck and game on!
Jul 26, 2010 | Sega Master System Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
How do I set up a sega genesis?
here we go
This is a step by step with testing set up for the sega mega drive
first plug the power plug into the mega drive and turn it on (there should be a red LED light)
plug RF lead into the back of the TV and make sure the switch is set at the megadrive side and not the ariel side, if you have a switch. (or you can buy scarts from www.retro-cache.com)
Now turn off mega drive, put a game into the slot and and then turn the console on
Select a channel on your TV and re-tune it into the mega drive. (on some TV's the tuneing is around the C36 area if that is any help)
If you tune into a blank screen than turn the mega drive off, remove the game, clean it and replace the game and try again.
Oct 01, 2008 | Sega Genesis 2 Console
Slight picture, no sound
sounds like you might have 1 of 2 problems
1 you need to fine tune your tv correctly
2 the lead you have may be worn and have a poor signal coming through
Also you might like to upgrade to an RGB Scart
www.retro-cache.com
You will end up will a far better puicture
Jul 28, 2008 | Sega Genesis Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Sega Genesis 2 Console Logo
194 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
