Question about Samsung SGH-D900 Cellular Phone
SERIOUS HELP NEEDED
I switched from NAM 1 to NAM 2 and the phone is asking for ENTER CODE...which is a 4 digit code...and well...I don't know it....Please help type the code you gave me and then what
    Brigadier General:
  • 7,752 Answers
Do a hard reset *2767*3855#
Posted on Jun 28, 2008
I changed the NAM 1 to NAM 2 on my samsung u360 verizon phone; how do i unlock my phone?
Please Try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 06, 2012 | Cell Phones
Sch-r350 nam 1 switched to nam 2 unlock code
Jul 23, 2012 | Valor Samsung SCH-R350 Freeform Premium...
How do tyou unlock your phone if you changed the setting to nam 2
So you're playing with all the settings in your phone and you notice this nice security menu. Wow, maybe you should enable the lock code. But you don't want to have to enter the lock code all the time, so you set your phone to only need a code when it turns on. Ah. Some piece of mind. What's this other sub-menu? Network? What's a NAM? Hmm. Let's set NAM 2 and see what happens. EEEK! Your phone's rebooting. Why's it doing that? Okay. Here's that new prompt for the security code. It's okay. I remember it's the last 4 digits of my phone number. Oh No! That didn't work. Unfortunately, when you switched to NAM 2, you switched your phone over to a different phone number. Your code's no good. Your phone is useless.
There are 2 solutions. The safest and best solution is to take your phone back to Verizon and have them reprogram it. A few people have told me Verizon is uninterested in doing this. A more risky solution is below. It will reset your phone to its original settings and erase all your phone numbers you have in the phone but it should get your phone working again. I've never had to fix this problem on my own phone, but a bunch of people have emailed me their thanks to say that this works. If this doesn't work or you make it worse, please don't blame me, especially if you don't follow the directions very carefully. I believe this proceedure works, but there is one mistake that if you dial a 9 at just the wrong moment, then you're going to be guaranteed making a trip to Verizon (so speaks the voice of experience). So, without further ado, here's the proceedure:
Do this exactly:
  • With your phone on, dial 47*68#13580
  • This will bring up a menu that says something like "-TEST CDMA-"
  • Dial 22
  • Your phone will now say "Send NAM 2"
  • Dial 222222 (the number 2, six times)
  • With each key press two digits will appear on your screen. Something like "000000-84100". Write down the 3 digits after the dash (e.g. 841). These are the first 3 digits of your unlock code.
  • Dial #
  • Dial 73
  • Your phone will say "Clear All." and it will just sit there for a while. Don't panic, just let it clear all the settings. It's not clearing the programming, just all the ringers and key beeps and menu settings that you entered (and more importantly, its reseting your password to something predictable). After about 30 seconds a "." will appear after the 73 you dialed. when that happens, the menus are cleared.
  • Dial 02
  • This will reboot your phone.
  • When the phone finishes restarting try the 10 possible security codes that start with the 3 digits you wrote down (e.g. 8410, 8411, 8412, 8413, ...). One of those codes should work.
  • When your phone is unlocked, switch back to NAM 1 by pressing Menu, 0 for Setup, 2 for Network, 1 for Set NAM, and select NAM 1.
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I have a sch U740 samsung phone nam 1 code
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
Jul 09, 2009 | Samsung SCH-u740 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
INITIAL PROGRAMMING NEEDED ON JUKE?
you can't fix it you have to get a new one...the same thing happened to me and im getting a new one
Dec 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
NAM2 locked.
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=22&AT_ID=87077&ARS_ID=9833651
its in the samsung frequently asked questions. All you do is go to windows calculater turn it to HEX enter the hex number under your batery switch the calculator to dec and the last 4 numbers is the NAM2 code
Oct 26, 2008 | Samsung SCH-u740 Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
