Question about Apple iPod nano
IPOD WILL NOT TURN ON - Apple iPod nano
  • Anonymous Aug 24, 2008
    this is the SECOND 30 black ipod that will not turn on. happens sometime after the warranty expires. i have tried using other charger - does not work (my other ipod works fine) this is sooooo lame. there are many other people i run into with the same problem. when i go to the apple store and talk to the glassy eyed clerks i get the same answer, "i'm sorry sir, there is nothing we can do since your warranty has expired" Next!  SO MICROSOFT.
    Guru:
  • 158 Answers
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Posted on Dec 03, 2008
  • 981 Answers
Your iPod is aghast at your habit of typing in all caps, and until your behavior improves; no music for you.
You should probably endeavor to see if someone else's charger can bring it to life, and then fix your charger; or of course the battery can be dead or the switch somehow destroyed.  You need to drop little clues, because it isn't as though people get your message and send a CSI unit out, relentless and singularly interested in helping you groove out.
Posted on Jun 27, 2008
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Apr 01, 2016 | Apple iPod touch
Ipod will not turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod.
When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch.
Press any button to turn on iPod.
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet.
Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge.
iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes.
If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Sep 08, 2013 | Apple iPod Audio Players & Recorders
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Ipod does not power up
Mar 24, 2013 | Apple iPod Audio Players & Recorders
Ipod Touch wont turn on
Your iPod has been working fine and all of a sudden it won't turn on. Not sure why? Before you rush to your nearest Apple store, try these easy-to-use, at-home solutions for fixing your iPod.
Check the Hold switch to see if it is off. Located on the top or the bottom of the iPod, when it is in the "on" position you will see an orange patch of color. Slide the switch until the orange coloring disappears. Try to turn on the iPod. Make sure the battery is fully charged by connecting your iPod to your computer's built-in FireWire or USB port or into an electrical outlet using your Apple iPod power adapter. Note: iPods without a click wheel cannot be charged using a USB port. After your battery is fully charged, try to turn on the iPod. Reset your iPod. iPod Shuffle: Disconnect iPod Shuffle from the computer if connected. Move the power switch to the off position. Wait five seconds. Move the switch to the play in order or the shuffle position. iPod Touch: Press and hold the Sleep/Wake and Home buttons together for at least 10 seconds until the Apple logo appears. iPod Nano (all generations), iPod Classic, iPod Mini: Turn the Hold switch on and off. Press and hold the Menu and Select buttons at the same time until the Apple logo appears, making sure to not touch any part of the click wheel. This should take about six to eight seconds and may need to be repeated. If your iPod still won't turn on, check the following: Make sure the iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard and iPod, and try again. Double check that you are using the FireWire or USB cable that came with your iPod, and that it is in good condition. Try the built-in port of a different computer.
iPod won't turn on
http://support.apple.com/kb/ts1383
Mar 01, 2013 | Apple iPod touch
Dos not work
Reset iPod
hope this helps
Sep 05, 2012 | Eclipse Audio Players & Recorders
My ipod wont shuffle anymore
How to Fix an iPod Shuffle That Won't Turn On
Things You'll Need:
* iPod Shuffle iPod USB cable Power adapter
The iPod Shuffle is the smallest member of Apple's line of MP3 players. During the device's lifetime, you may find that the iPod freezes or seems to not turn on anymore. Since the iPod Shuffle does not have a display attached to it, you cannot be notified of any device errors. However, there are several troubleshooting steps you can take to repair your iPod.
Instructions
Plug the iPod USB cable into the iPod Shuffle and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod Shuffle to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod Shuffle memory.
Connect the iPod Shuffle to your Mac or PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Hope it helped.
Have a nice day.
Feb 22, 2011 | Apple iPod touch
My ipod is not starting
Hi, here are 3 options: 1. Give it a good charge on the computer.
2. Erase all your songs on it so it has a chance to recover
3. How do I fix my iPod if it will not turn on, turn off, or wake up?
"Your iPod Won't Turn On" from the Apple Support Site provides in-depth instructions for troubleshooting an iPod that won't turn on. Apple recommends that you:
1. Make sure the Hold switch is off
2. Make sure the battery is charged
3. Reset iPod
4. Let iPod's battery drain
5. Update iPod's software
6. Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
7. Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
8. Try connecting iPod to the built-in port of a different computer to see if that works.
"iPod Stops Responding or Won't Wake From Sleep" from the Apple Support Site notes that you need to "charge your iPod, then reset your iPod" if it won't turn off or wake up.
For solutions to other specific problems, please refer to the iPod Troubleshooting & Repair Q&A and try the iPod Help links provided for each iPod model on EveryiPod.com.
If after going through all of the above, the issue appears to be a hardware problem, site sponsor Mission Repair offers free hardware diagnosis and an affordable 24 hour repair service by mail for all iPod models.
Have a nice day and Goodl uck to you.
Feb 16, 2011 | Audio Players & Recorders
My ipod wont turn on
If your ipod won't turn on then try these.make sure you click on the blue links for more info.
  1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
  2. To turn the hold switch off, slide it until you no longer see the orange patch.
  3. Press any button to turn on iPod.
ts1383_2.jpg To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
Reset iPod If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
  1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
  2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
May 16, 2009 | Apple iPod nano
Ipod
Your iPod Won't Turn On" from the Apple Support Site provides in-depth instructions for troubleshooting an iPod that won't turn on. Apple recommends that you: 1. Make sure the Hold switch is off
3. Reset iPod
Dec 11, 2007 | Apple iPod nano
Apple iPod nano Logo
69 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
