Question about Epson LQ-2180 Matrix Printer
Wrong adjustment using epson LQ-2180
I got problem. my printer (epson LQ-2180) can't load paper (I use continuous paper), I must to roll manually when printer on, then printer will "catch" the paper automatically. and also, the result, sometime fonts seem fade out.
and, when I press LF/RF button (to rewind/forward paper), the printer can't roll paper correctly. when I press to rewind, printer roll forward.
how to fix it, or what is the problem?
really appreciate your help. thanks
  • 1 more comment
  • freddy_jaya Jul 07, 2008
    for Stickx
    yes, paper get damage when reset to beginning, but not when feed. what is possible cause? thanks
  • ossy_suryono Oct 12, 2008
    my priter cant load paper from bottom and up??. How to open and clean the cencer
  • Anonymous Feb 04, 2009
    MY NEW PRINTER EPSON LQ-2180 IN FACING PROBLEM OF PAPER TEARING ON HORIZATAL LINE.
    Novelist:
  • 148 Answers
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Posted on Jun 27, 2008
For stickx
the paper get damaged when reset to beginning. but, when try to feed, paper not get damage. so, what is possible cause?
Posted on Jul 07, 2008
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
My printer epson lq-2180 print a blank paper and continuously ask me to feed paper..after i feed paper the same situation happen..it print a blank paper and continuously ask me to feed paper..this...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed.
Jul 06, 2011 | Epson LQ-2180 Dot Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 continuous printing problem
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Mar 09, 2010 | Epson LQ-2180 Dot Matrix Printer
How to check paper end sensor for epson lq 2180
have to remove all the covers and its located in the paper load tray at the back has a plastci trigger lever and operates the internal switch what happens is the lever wears off or breaks on the end but the switch does go bad itself
Jan 22, 2010 | Epson LQ-2180 Dot Matrix Printer
Paper out
Have you considered buying an ink jet printer? You will find your money will be well spent. Epson all-in-one printers can be bought for less than $100.00 when they are on sale.
May 27, 2009 | Epson LQ-2180 Dot Matrix Printer
LQ 2180
There is a problem in panel
u need to check panel cable if it is connected properly
if the prob. doesn't be ended then u need to use another panel
Feb 03, 2009 | Epson LQ-2180 Dot Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Matrix Printer Logo
946 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
