Question about Standard Horizon HX260S 2-Way Radio
HX370S Can Not TX
I got an unit HX370S when press PTT is not TX . but can RX..
what the problems??
    New Friend:
  • 109 Answers
There are too many posibilities to your question the best thing to do is to have it checked out by your local two-way radio service center.
Posted on Aug 21, 2008
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
When I press the speak button, It display's TX and the other radio displays RX
tx is the word for transmit and rx is for receive
if you press the talk button, the unit goes into transmit mode and is received in the receiver of the other unit/s
now that your statement has been clarified what was the question?
Feb 26, 2016 | Radio Communications
I have a vhf 25 W radio set . Rx is ok but no Tx .my ptt is ok then whats the problem
A lot more information is needed to get started on helping your resolve your problem. First, you have not provided any information about your radio (make and model at least). You said that your PTT is ok, but no transmit. The PTT is just a switch to switch between RX and TX.
Have you tested the output with a watt meter into a dummy load? What other tests have you performed, when did the problem start, and what was being done prior to the start of the problem.
Have you talked to any local ham radio operators about this problem and asked for their assistance?
Mar 17, 2015 | Radio Communications
I have a Vintage kinematix reverb with 5 wires red,yellow,white,brown and black how I hook it up what are the wire? it also has a delay tuning knob
usualy you have a transmit recieve switch
like this
.....common
RX <<-- >TX ptt
so three wires
the ptt button common in a cb with 4 pins is also ground
should be
black screen and i think brown
but you need to meter out the ptt common and RX TX
for rx audio switched radios then one pin is RX one pin is TX one pin is common or ground for the PTT and also ground for the screening copper braids and also ground for the transmit audio
so you have 5 wires
3 will be PTT 1 will be audio and one audio ground
usually white or yellow
so i think black and yellow or black and white
black being ground
just look up the schematic or service manual for your CB
and check out the 4 pin plug config
there is only two usual ones
cybernet or uniden so.. easy stuff
look for like cybernet cb 4 pin wireup in google or similar
remember just meter out using the beep test range on a cheep multimeter too see which three are the PTT
so the common of the ptt needs connected to the copper screening and also to the black wire all to the ground pin on the 4 pin plug
you can short from the ground pin on the cb side to its TX pin and the set will enter tx mode
same with rx audio enable {if uses most cb post 1984 dont use RX audio hard switching}
so just three pins to worry about
Dec 03, 2014 | Radio Communications
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Radio stuck in RX mode.
Your PTT button is possibly at fault. It may be partially depressed, leaving your receiver open. Behind your PTT button there is an internal PTT button on the componet board. It may be stuck or defective.
Feb 28, 2010 | Radio Communications
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Squelch when keying ptt
I would check my ptt wiring making sure the button is set so that when you push it it switches you from RX to TX. If you have a wiring diagram that would be helpful if not are you able to get one? In any event make sure the wires are not misconnected.
Sep 12, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Standard Horizon HX260S 2-Way Radio Logo
116 people viewed this question
Top Standard Horizon Radio Communications Experts
AnyMHz.com
AnyMHz.com
Norm Pearl
Clint Millett
Are you a Standard Horizon Radio Communication Expert? Answer questions, earn points and help others
