TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
