Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Turning my saa7130 into my default audio card
I have no problems with the saa7130 tv tuner,
what am trying to do is use it as my default audio card
because my original audio card is broken and has no audio. can any body please tell me how to do this? thanks
I went through the same issue when I bought this unit new. After going round and round, I learned that you MUST use the little dual plug audio wire to put on end into the video card OUT plug (green out line) and the other end into the Audio Card IN (blue in line). That will splice your TV Card into your audio card and sound will miracuosly appear (once you fine tune your audio outputs!). Hope that helps!
Posted on Jul 09, 2008
Not install software SAA7130 TV Card Please Help me for your download software. thank you
I have a honestech TVR Tuner card (Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture) on my *other* computer. I can watch tv no problem, i see stuff, and there's audio. But when i record, i can only record image, no sound. It asking for digital singh and not instaling praperly
Aug 03, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a frontech pci tv tuner card with philips chipset SAA7130 installed on pc gives images but no sound?
Hello
The package contains an audio cable, connect the cable audio out from card to audio in of computer and connect the speakers at the same place where it is,
or you can directly get audio from tv card by connecting speakers to audio out connectors.
Hope this helps, if so do rate the solution
good luck
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I want saa7130 tv tuner driver for windows 7
Try this link and down load: http://www.pcpitstop.com/drivers/download/SAA7130~TV~Card~-~TV~Tuner.html
Jul 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says adding video tee smart failed what will be the reason for this problems
Pixel view pro3 SAA7130 TV Tuner/FM Radio/Video PCI Capture card after installings it says cannot render video capture pin to null filter plz help me
Jun 04, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
ENTER saa7130 tv capture card not working properly
You need to make a cable with both ends with 3.5 mm jack socket. Plug one jack socket in audio out from tv tuner and the other in the line in from your sound card and will work.Good luck
Apr 01, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sound problem with recorded video.
Check your sound properties. It is probably defaulted to a low setting. Try raising the setting to one that says DVD quality and see if that fixes your problem. Hope this helps.
Mar 14, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems
Have you checked the installation? - most PCI capture cards use the audio card of the PC for sound. A jumper cord is needed to come out the capture card and into the audio line-in jack. Green jack on the capture card is OUT, and the Blue jack on the sound card is Line IN.
Jun 17, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
SAA7130 TV Tuner...
DOuble click your speaker icon near the clock. click file then advanced, in the advanced menu select teh RECORDING radio box and click OK to return to your volume adjustments.
toggle the check boxes under each input and make sure they are turned up while you are trying to watch tv. when  you find the one that has the sound from your tuner go back to the advanced menu and make sure that input is checked under playback.
May 02, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
You can use DScaler in Windows XP and Vista, it works with this card.
Dec 28, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
296 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
