Question about Kodak EasyShare Z7590 Digital Camera
Got wet Camera got wet on a canoe trip. Spashed not dunked, but now it pops when i turn it on, I need to know how to dry it out.
  • 34 Answers
Put it in a container of rice or popcorn. the rice naturally absorbs moisture. all it will take is 24 hours
Posted on Jun 27, 2008
What is error code E23?
Traditionally, the E23 error code in Canon Powershot models is the CF/SD card memory full error. Do you get the same error message when using another card or when there is no card in the camera?
If you've tried a different memory card and made sure it's inserted properly and still get the the error then the camera is water damaged. Canon repair manuals indicate the E23 error is generated from the "PCB board" (main camera electronics) so the only option would most likely be a board replacement.
HOWEVER - I can make this suggestion. I had a Canon DSLR get submerged underwater in a "moose vs canoe" incident some time back. I read to remove the battery and memory card (leave the doors open), wrap the camera in a clean, paper bag and completely cover it in a bowl of plain, dry, uncooked white rice to absorb moisture that may be trapped in the camera. It's a last ditch effort and may already be too late, depending on how wet your camera got and how soon you can do this. You'll need to leave it in the uncovered bowl of rice for at least a week and keep the bowl in a dry area. This worked for me but my camera was completely submerged for less than 10 seconds. Good luck!
Aug 09, 2014 | Canon PowerShot SX170 IS 16 Megapixel...
Wet phone dried out but rejected battery it had when dunked. is the battery trash or can it be fixed? It is a new battery less that two months out of the box......?
my phone turns on when plugged into the charger, however it only says battery is full... someone told me there is a series of keys you can press to open into the phone... HELP
Aug 10, 2013 | LG VN250 Cosmos Battery LGIP-340NV 950mAh
My D3100 got dunked, it works but images seem cloudy
Bob, Your camera may stop working very soon as corrosion begins. You should place all parts that got wet in a pillow case and put in a large container of dry, uncooked rice for a day or two (or longer). The rice will will draw out the moisture from all the affected parts.
Next, you'll need to do a "wet cleaning" of the sensor. This is not for the faint of heart - but can be done at a camera shop for under $100 if you'd rather have them do it. I'd wait a couple of weeks before doing that - as the camera may fail as a result of the corrosion I mentioned earlier. It doesn't make sense to drop $100 into a broken camera - right?
The lens will need a thorough cleaning - but may be better / cheaper to buy a replacement. This is not an "end user" job - it will need to be sent out - but consulting a local camera shop first would be best.
Nov 18, 2011 | Nikon D3100 Digital Camera
What are the holes in the seats for?
To allow water to drain through it when it gets wet (and it will) rather than make a puddle that does not dry out until you sit in it.
Jul 21, 2011 | Pelican International Pelican Dlx Canoe ...
My camera got wet with fresh water. I let it dry, but it doesn't turn on. Do I need to buy a new one?
Maybe not. It depends on how much water got in and maybe is still in, and whether the battery is busted, shorted or just depleted.
I'd suggest keeping the camera for some days in a really dry place - you can heat an oven to about 50 degrees, not more, ABSOLUTELY NOT a microwave oven!, and place the camera in a small sealed carton box with some packs of silica gel (can easily be found in electronics and musical instruments stores - they just throw them away). The silica will **** out all moisture from the air. Higher temperatures might damage the plastic, so must be avoided.
Meanwhile, you will have extracted both SD card and battery from the camera (it's best to put it in the box with all plastic doors wide open to ensure circulation), and will have cleaned the SD contacts and the battery terminals. Try charging the battery with the Casio charger to full capacity.
After the camera is assuredly dry as a bone, put back the charged battery and see if it works.
This worked with my Exilim 500, but it had been dunked for a few seconds only; I don't know whether yours ended in water long enough to trigger electro-oxidative damage from live circuits. It's worth a try nonetheless. Let me know...
Jul 02, 2010 | Casio EXZ550 Digital Camera
Gear for canoes
Here's a list of some of the other gear we would suggest: - A sturdy roof rack on your car (it will greatly reduce problems and add to your enjoyment). - Bow and stern tie-down lines - these are critical to the safe transport of your canoe when you are on the road. - A set of wheels to make getting your canoe to the water easier. - A bailer and sponge. - Padded canoe seats for longer journeys. - Dry bags to keep extra clothes and snacks protected from water coming in off your paddle, as well as from bow spray or rain.
Dec 01, 2008 | Advanced Elements Straitedge Canoe
DSC-W90 GOT WET AND NOW POWER BUTTON DOES NOT FUNCTION BUT CAMERA TURNS ON WHEN YOU PUSH THE MENUE BUTTON!!
it got wet and you are asking for help to fix it? maybe go to a nearby swimming pool, dunk it there for five hours and see if it works.
Oct 27, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Storm ravaged old film camera- no power
Water or any liquid is a camera killer, unless it's a under water camera. don't know of any camera repair shops that will repair liquid damaged camera's Reason---- cannot guarantee them. So it looks like you have a neat paper weight.
Oct 13, 2008 | Photography
Camera went for a quick dip in the lake
I've rescued cameras and cel phones from such a fate, but I worked on them while still wet. After they dry, not much hope, sorry
Aug 23, 2008 | Cameras
Dropped camera in pool
If it does not fire up, I would dunk it again - this time in warmed, distilled water, moving it around a bit, then putting it in a warm (not hot) place to dry but I would probably give it a week.
Distilled water is non-conductive whereas pool water is . . . who knows?
Jul 10, 2008 | Canon PowerShot A520 Digital Camera
Kodak EasyShare Z7590 Digital Camera Logo
96 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
