Question about Sony Ericsson K800i Cellular Phone
I can't heard anything! I can use it only with the hands free
I am not sure if it was a drop or what but at the moment I can't use it because the ear speaker is not working
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and ahve the ear-piece replaced.
Posted on Sep 07, 2008
Can you help me cancel a membership that is signed up for at the spark of the moment? As I cannot get any assistance from the company to cancel it.
They will do as they are getting their money.
We cannot do anything except suggest stopping payment and returning the vouchers may get you somewhere.
Sep 26, 2017 | The Computers & Internet
Electrical problem on my 96 Geo Tracker
you need to ID the relay.
where is it. ?in cab or in the engine bay.???????
and for sure can be found and fixed
does car run? (a shoe drop moment)
this page helps ID parts
http://www.fixkick.com/find-parts.html
your engine is a G16B (16valve) for sure, i owned 2. (restored them)(
the 96 geo has a bank of fuses behind the glove box, mounted to the
heater .AC box. there. does that buzz?
if not sure use a rubber hose to your ear to listen to any relay or VSV for free.
find it, first. report it or
post here.
http://www.fixkick.com/bbs2/Suzuki-bbs/forumdisplay.php?fid=2
one cause of relay buzz is a bad fuel pump, it draws over 4amps
and overloads the ECU power feed. causing ECU to go, quite nuts.
Mar 28, 2014 | 1996 Geo Tracker 2 Door
Does the phone have hands free handsf
Most cell phones are supplied with ear piece and mic set that allows the cell phone to be used as a hands free phone.
If your cell phone is Bluethooth enabled then you can also connect to a hands free ear and mic Bluetooth set.
Dec 23, 2011 | Cell Phones
I don't have the directions how do I work it i have ThermoScan and want to use on 4month old
How to use Braun ThermoScan 1. Always make sure a new, clean lens filter is in place to help ensure an accurate reading. The thermometer will not function without a lens filter attached (see Changing the lens filter). 2. Press the /mem button. The LCD (liquid crystal display) is activated, showing all segments. When the ready symbol is displayed the thermometer is ready for use. 6 To help ensure an accurate temperature reading, use the following technique: If you are right handed, hold the thermometer in the right hand and take the temperature in the right ear. If you are left handed, hold it in the left hand and use the left ear. 3. Perform an ear tug to straighten the ear canal. This gives the thermometer a clear view of the eardrum. Children under 1 year: Pull the ear straight back. Children aged 1 year to adult: Pull the ear up and back. An ear tug is best performed by using your free hand to grasp the outer edge of the top half of the ear. To take your own temperature, wrap your free hand around the back of your head and grab your ear from behind. 4. While tugging the ear, fit the probe snugly into the ear canal as far as possible and press the activation button. Release it when you hear a beep. This is the Temp Beep that confirms the end of measurement. 5. Remove the thermometer from the ear canal. The LCD displays the temperature measured. 6. Replace the lens filter after each measurement: press the ejector button and put on a new, clean lens filter. 7. A new measurement can be taken as long as the ready symbol is shown. If no button is pressed within 2 minutes, the thermometer will turn off automatically. 7 Note: In the following situations, it is recommended that you take three temperatures in the same ear. If they differ, use the highest reading. · Infants in the first 90 days of life. · Children under three years of age who have a condition such as a compromised immune system and for whom the presence or absence of fever is critical. · When you are first learning to use the ear thermometer until you are comfortable with the technique and are obtaining consistent readings. Important: As with any type of thermometer, slight temperature variations ( ± 0.3 - 0.5 °F / ± 0.2 - 0.3 °C) can occur, if consecutive measurements are taken. Temperature taking hints · The right ear reading may differ from the reading taken at the left ear. Therefore, always take the temperature in the same ear. · The ear must be free from obstructions or excess earwax buildup to take an accurate reading. · External factors may influence ear temperatures, including when an individual has: - been lying on one ear or the other - had their ears covered - been exposed to very hot or very cold temperatures, or - been recently swimming or bathing. In these cases, remove the individual from the situation and wait 20 minutes prior to taking a temperature.
Mar 04, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I cant hear voice over the ear piece
you need to change the flat cable the one that goes to the screen because its the one that supplys voltage to the Earpiece .
Because of the sliding everytime it gets damaged or dropping down also does damage it
The earpiece is still fine .
May 25, 2009 | Nokia 5200 Cellular Phone
Ear drops for scuba diving so my ears don't hurt while under water
These ear drops and other similiar drops, are to be used AFTER you leave the water only! DO NOT put ANYTHING in your ears before or during your dive. This product and others like it contain an alcohol base which tends to purge and helps evaporate water which may have entered the ear canal. Your eardrums must be able to compensate for the difference in the atmospheric pressure at depth. Putting anything in your ears before or while at depth can interfere with this process and could cause serious damage to your inner ear.
This product is great for using AFTER the dive or just swimming. :)
Apr 06, 2009 | Trident Ear Drops for Scuba Diving,...
I can not hear anything from my caller
i think what you speak will be heard by the persons who call you ...
you cant hear there voice because there is some loose contact in the speaker(ear piece) or it is dead or broken ...
if you are good at opening the handset then open it and refit the ear piece speaker correctly or if there is a problem in the speaker then it can be solved by replacing it ...
if you no idea of opening then just visit the technician he will do it but he may take some service charge for that ..
but the ear piece speaker is not at all costly it is very cheaply available ...
check the call volume while on call once before you do the above ...
i am sure you will be able to play the music ... dont just get confused because there will be 2 speakers in the handset one is the ear piece speaker which is used to hear the calls and one more is the loud speaker from which the music,etc will be heard ...
thank you
regards
-Dileep
Nov 08, 2008 | Nokia 5200 Cellular Phone
IS MOTO RAZR S9HEADPHONE WORKS WITH MOTO RAZR V3I
If your phone supports the A2DP bluetooth protocol, music you play on the phone will be heard in both ears of the S9 headset.
Voice calls are always in one ear only.
May 24, 2008 | Motorola Mobility S9 Headphones
Dropped Phone in Motor Oil
LMAO!!!! So sorry as its not the first time I've heard this .. Your gonna need to get some sort of degreaser for electronics such as chemtronics products, such a tun-o wash type product that dosent have any lubercant in it. Now once you get this spray, spray alittle on the back of the phone to make sure it dosent desolve the bloody thing. If it dosent, start spraying all the stream into the mouth and ear piece, while at the same time shaking out all the oil as it should if you get the right stuff. Them its gonna get really cold with this spray so dont hurt your self. Now make sure the batterys unpluged and let the unit dry up for a day or two and then insert the battery again and see if it worked or not. You got a 50:50 shot . If it works great Im a hero, if it does Not, OH well i tryed.. Good Luck
May 30, 2006 | Samsung SCH-a650
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
