Question about Nintendo Wii Console
Trying to connect my wii through a wired modem
You need a rj45 connecter to hardwire the wii. ethernet to usb. try ebay
Posted on Nov 10, 2008
Well every time i try connecting the wii say error # it gives a new number everytime
Posted on Oct 04, 2008
  • angerqueen21 Oct 04, 2008
    my wirelss internet conection says error 51330
I cant get the internet to connect to the wii
I'm getting Error Code: 51420 when trying to connect to the internet with the Wii console.
This is our first time trying to make internet connect with the Wii console. I have a USB cable connect from Wii console to the Modem. Any help
Jul 16, 2011 | Nintendo Wii Console
Wii says needs update in order to connect with Wii Store which would allow me to download NetFlix Ap. It is connected to the net but I keep getting error message that says update could not go through. It...
Hi there!
There are two ways to connect your Wii to the internet; you can connect to your wireless network (if you have a wireless modem set up in your house), or you can connect using a wired connection directly to your modem.
If using a wired connection, you will need to purchase a Wii LAN adapter and connect that from your WII into your wired router.
Once you have figured out what connection type you will use (and if using a wired connection, purchased and connected your Wii LAN adapter) you will need to take the following steps:
FOR WIRELESS CONNECTION:
  • Turn on your Wii and click on the "Wii" button on the bottom left of the screen
  • Click on "Wii Settings"
  • Click on the arrow on the right side of the screen and select "Internet"
  • Select "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click on "Wireless Connection" and then "Search for an Access Point"
  • Select "OK" and the Wii will display all the wireless networks it finds.
  • Select the wireless network that is yours.
  • If it asks you to enter a password or key, then your wireless connection is password protected and you will need to enter the password that was setup to allow access to your network.
  • Select "OK," "Save Settings," and then "Yes."
  • Your Wii will test the connection and you should get a message saying connection was successful.
FOR WIRED CONNECTIONS:
  • Connect your Wii to the Wii LAN adapter and connect that to your modem or broadband adapter. Please not that you will need to unplug your modem for a few minutes to reset the connection and you will also need to unplug the connection to your computer when you want to connect your Wii to the internet.
  • Turn on your Wii and select the Wii icon on the bottom left
  • Click the arrow on the right side of the screen and select "Internet"
  • Click "Connection Settings"
  • Click "Connection 1 : none" (if you don't see "None" in Connection 1, click the Connection 1 button, then choose "Clear Settings")
  • Click "Wired Connection"
  • Click "Ok"
  • Your Wii will now do a connection test
  • You should see a message saying the test was successful
Hope this helps!
Jul 06, 2011 | Nintendo Wii Console
Trying to connect to internet on my wii console but it comes up with error code 51420
error code 51420 means The Wii console is not able to connect to your wired router or modem.
Try to do this step hope it will help you plzz rate me tnxx...
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 04, 2011 | Nintendo Wii Console
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
Apr 03, 2011 | Nintendo Wii Console
I have direct tv and I am trying to hook my wii up so I can watch netflix it is giving me an error 51420
Error Code: 51420
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51420&system=Wii&locale=en_US
Apr 01, 2011 | Nintendo Wii Console
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
Connecting directly to a modem:
1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
1. On your PC, click "Start" and then "Run."
2. Type "CMD" into the field that appears to open a new window.
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE.
Mar 15, 2011 | Nintendo Wii Console
Connecting internet
The Wii has built in WiFi so if you have a wireless modem all you will need to do is go to the Wii settings menu and select Internet, Next choose Connection Settings then select Connection 1. Here you will have the option to choose a Wireless conection -OR- Wired connection. If you have a wireless modem or Router click Wireless connection and choose Search for an access point then
select your access point from the list. Save then start a connection test.
If you do not have a wireless modem or router you must buy the LAN Adapter which you will find here http://www.amazon.com/Wii-LAN-Adapter-Nintendo/dp/B0014KM2KG. You will need that to connect a ethernet cord from your modem to the Wii. You would choose Wired connection and click ok to start the test. Good luck and have fun (",)
Jan 04, 2011 | Nintendo Wii Console
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance
Sep 13, 2010 | Nintendo Wii Console
Unable to connect to internet
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
Jul 06, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
61 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
