Question about Motorola Mobility ROKR E6 Smartphone
Cant recieve calls suddenly, but able to call others
My Motorola ROKR E6 suddenly couldnt receive any calls. I tried my sim card with my other phones and they can recieve calls. On the ROKR i can only call others and text msg others and receive text msgs, but unable to receive calls! help me plz
  • 4 more comments
  • unrealll Jul 03, 2008
    same problem. sometimes i can receive calls and sometimes none at all but when my phone does not ring, i receive a text message saying I've missed a call, part of Fido's new promotion i believe. Ever since this promotion my rokr couldnt recieve calls. please help.
  • Nassau Jul 13, 2008
    Same problem with me as well. One fine day my rokr has started behaving like this. I dont recieve incoming calls by says my phone is unreachable to others but if you try 5-6 times then they get through to me. I onoy recieve a msg if i send one message or if i recieve a call and i pick it up. The same problem as the guy aboive has mentioned
  • thr1lla Jul 16, 2008
  • stillplayin2 Aug 11, 2008
    how would you change name display? where can i find that in my phone
  • sid78669 Sep 11, 2008
    Same problem here, but i am with Fido. Will get the name display option disabled tomorrow, lets see. Will post if successful.
  • InuN Dec 27, 2008
    I Have the same problem as well. I even gone even worse than all of the above. I went back to the place i purchased (hong kong) and got the WHOLE MOTHERBOARD replaced. It works in HK, but when i come back to Canada, it doesnt work ****. Its prolly with Fido/Rogers. Or Fido/Rogers doesnt support this phone ==" but i hope it does. I will try the cancelling caller id with fido/rogers;
The solutiuons above are 110% correct! i tried calling from another phone, while setting it to ned send its number, and my E6 recieved the call immediately although it was not doing so before the change. Thus, it seems that Name Display is the problem! get it deactivated to get your phone working!!
Posted on Sep 11, 2008
I have the same problem, and it only began after flashing the firmware on the device. ive flashed it with different firmwares about 4 times with 4 different firmwares, some default (stock) firmwares, some are monster packs and the problem continues. i even bought another one and after flashing, i had the same problem. Rogers does not support the device, only the E1 (which ive upgraded from) and E8 ROKRs (as you all probably already know) so getting help from them will be difficult. however, i have my doubts about Solution #1, because disabling Name Display only applies to outgoing calls, not incoming calls. if anybody here has actually solved this problem yet, please confirm your solution, because i (and others im sure) am not going to be changing phones for some time. I happen to like this phone.
Posted on Sep 06, 2008
Okay.. what you should do is call ROGERS tech support. Tell them to DE-ACTIVATE your NAME DISPLAY. Thats it people.
Posted on Aug 29, 2008
If you're with rogers, then you should turn off name display
Posted on Aug 05, 2008
E6 roker insert sim
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
Jan 11, 2011 | Motorola Mobility ROKR E6 Smartphone
Sir i own a motorola rokr e6 phone. i want to set the email settings on this . plz help me. i saw the settings on nokia e63 it works very well all email coming like a message. plz tell me this for rokr...
To get the internet/GPRS setting please call your service provider.
They will send you the internet/GPRS setting.After you recieve please save the settings to your phone and make it as default setting.
You can start using this service
Jul 28, 2010 | Motorola Mobility ROKR E6 Smartphone
Can someone please help me figure out whats rong with my phone......i can't make or recieve calls it says no service on the diplay and when i try making call it says call failed.
Do you have a valid Sim card in the phone? Is the SIM card inserted correctly? They really are easy to get in wrong. You have to look at the phone under good light where the SIM card goes, and you will see a notch which correlates to the notch on the SIM card. Put the SIM card in just as shown and put the battery back in, turn it on and it should satrt working.
Jun 27, 2009 | Motorola Mobility ROKR E6 Smartphone
Phone Unlock code Motorola Rokr E6
Try d code 0000 or 12345 or 1234 one of these has to work....or try wipind out ur memory card and then try...format the memorry card...hope it helps....
Feb 15, 2009 | Motorola Mobility ROKR E6 Smartphone
Memory Card can't be recognized for Moto Rokr e6
Okie,in this situiation you try your memory card with the other phone,still can't recognize try to format your card still can't,last solution.......change new one.Now the day memory card very cheap....;)
Dec 30, 2008 | Motorola Mobility ROKR E6 Smartphone
Switching sim cards
one simcard can only be used in one phone at a time. the phone needs to be turned off to remove the sim card so nope...
Sep 04, 2008 | Motorola Mobility ROKR E6 Smartphone
Rokr e6
To New Guyxxx:
For me too similar problem comes rarely, I wl restart the phone and the problem will b rectified automatically. Try this, if u still face the problem You just remove your memory card frm phone and plug it again. Also ensure the memory card is working properly.
To Guest:
You have to use Motorola phone toolkit to copy and backup the contacts and messages. For E6 to be detected as Mass storage, the drivers are preinstalled in XP, so no need of drivers.
Aug 29, 2008 | Motorola Mobility ROKR E6 Smartphone
Cant place calls on my motorola rokr E6
Contact your telephone service provider to find out why your phone cannot access the network.
Your phone should follow all the basic standard protocols for mobile telephone communications.
Are you properly subscribed?
Is your service activated?
Jerry G.
Jul 30, 2008 | Motorola Mobility ROKR E6 Smartphone
My Motorola ROKR E6 fell in sewage water
If i am not wrong E6 of Motorola was launched recently , U will need to approach Service Center . As no one Online will be able to solve u r problem. The problem is between u r sim reader & Main Circuit , so it is better to approach Service Center
Aug 15, 2007 | LG Shine KE970 Cellular Phone
Motorola Mobility ROKR E6 Smartphone Logo
119 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
