Question about Pioneer VSX-D510 Receiver
I need set up help
I connected all the cords to this system and I have television picture but no sound from the speakers except static when i test them
  • 151 Answers
Most amps these days have to told which input is being used,ie if you have the dvd into dvd video input for picture and are useing coax or optical for sound you have to go into the setup menu on the amp and find the input menu and tell the amp the dvd is on optical or coax.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
Un55eh6030 sound off except for sound test then it works
Are speakers turned off in audio settings in menu?
Mar 18, 2014 | Samsung Televison & Video
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have no sound
consigning no sound on your TV
You might need to do some troubleshooting tips first before calling a repair man to replace the sound IC inside the TV.
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker.If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/humm pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness.
Check the volume setting. It might sound simple, but it's the best place to start. Make sure the television sound is not muted or turned all the way down using the remote or buttons on the front of the television. If the batteries are dead in the remote and the TV is muted or turned down, it might seem like the sound is broken.
Examine cables connected to the TV. Sometimes a loose connection can cause a loss of sound. Ensure all cables are tightly connected to the television and correctly inserted. Some peripherals are connected using a three-plug system and are usually labeled red, white (sometimes black) and yellow. Both the red and white leads are sound cables. Try removing all the cables (except the power) from the back of the television and turning it to TV mode, then listen for static or other sound.
Plug in headphones to the television with all cables re-attached. See if you can hear sound through the headphones. If you can, it may indicate that the TV's internal speakers are not working. If you can't hear anything through the headphones, it may be indicative of a larger problem.
Call a repairman. If at this point everything has failed to produce a sound, it's time to call in the professionals. A qualified technician should be able to fix the problem either at your home or in a workshop.
Aug 17, 2011 | Televison & Video
I have a 46 panasonic veska tv and I can not connect my vizio sound bar to it. I hear static but no sound
  1. Check the power. Don't be embarrassed if your problem is as simple as an unplugged power cord. It's better that you should discover this than pay a repair technician to come out to your house and find out.
  2. Isolate the problem. The main troubles that will crop up with a TV set are either no picture, no sound or both.
  3. Check the input setting on your remote control. If you have other devices connected to the TV, such as a video game system, those devices must be used with a different input setting than the input you use for watching programs or movies on a DVD or Blu-Ray player. Chances are, the kids were playing a game and forgot to turn the input back the way it was.
  4. Press the Input button on your remote control to return to the setting you wish to use. For example, the cable box might be connected to Input 1 and your DVD player might be connected to Input 2. Newer television sets have at least 3 inputs.
  5. Check the coaxial connection from your cable or satellite receiver to the television. The cable should be attached securely by twisting the round lock nut clockwise. Also check the power connections for the satellite or cable receiver. If either is unplugged, you won't receive a programming signal on the TV.
  6. Make sure the video cable is securely attached to the TV jack if you have a home theater system. The video cable runs from the Video Out jack on your home theater receiver to the Video In jack on the back of your TV.
  7. Check your receiver setting. Home theater receivers manage several components, so if you have the receiver set to operate the CD player but you are trying to watch a movie on your Blu-Ray player, you'll need to change the selection to Blu-Ray to watch the movie on your TV.
  8. Check the TV speakers to see whether they have been muted by accident. Press the volume button on your remote control or go to the Menu section and scroll down until you reach TV Speakers. Toggle left or right to turn the speakers on or off.
  9. Press the speaker button on your receiver to make sure your external home theater speakers are activated. Many home theater systems use external for their superior audio rather than the speakers inside a television.
Feb 05, 2011 | Panasonic Televison & Video
No Sound At all from the Speakers. I have plugged and replugged in the connections. I am getting power but absolutely nothing out of the speakers. Some minor static if I wiggle the power cord,...
no sound at all it was working fine before i got additional speakers creative sarrounding withe 2 mini and 1 sub buffer how to test it its just not comming on now
Jan 03, 2011 | Bose Companion 3 Computer Speakers
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
PT4231 have picture no sound, Selection is on internal speakers.
you can go to your menu and select the test tone just to see if your speakers are operational, if not replace the speaker. If you have test tone, then check your input connections. If everything is connected correctly then you need to replace your main board and that should resolve the problem.
Jun 22, 2009 | Norcent Technologies PT420 42 in. HDTV...
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
Pioneer VSX-D510 Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
