Question about Motorola Mobility RAZR V3
Razr inner screen fading, flickering
The inner screen is fading. When I press any button the color returns to normal but the bottom horizontal has white lines flowing through it, every other line is white/black/etc. The front screen (smaller one) is fine. This started about three weeks ago and varies to some degree in intensity.
    Brigadier General:
  • 7,752 Answers
Take the phone and have the LCD replaced on the phone.
Posted on Jun 28, 2008
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
My picture faded off the screen
Need to see if you're getting high voltage. See if you have 130v dc on the collector of the horizontal output transistor.
Nov 12, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Flickering Screen/Faded Colors
It sounds like a problem with the video card, whether it be on-board or a card. See if you or a friend has a spare one laying around and try that one instead. If it's not the video card, try a different monitor.
Jan 05, 2009 | Sony VAIO VGC-JS130J/B 20.1-Inch...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Screen Problem...
I had a similar problem with one of my laptops, there is a ribbon cable that connections the LCD screen to the board inside the laptop case that gets a little loose. In my case it was a easy fix because the button panel on my laptop popped right out and I could take the end of a pencil and push the connector back down into the socket; not all laptops make it that easy for you. If you laptop is still under warranty I would make HP fix it; there is also a chance the LCD screen could be burning out.
If you're not squeamish about fixing it yourself my recommendation is do the work at your own risk. The only hard thing about taking apart a laptop is putting the each screw back in the original location; many laptops have more than 5 different sized screws holding it together. Furthermore, you don't need to dismantle the whole thing; worst case there are 2 - 4 screws that hold in the keyboard and 2 - 3 screws holding in the forward button panel. Near each screw hole is an indicator what it is for; on my laptop it shows the letter "K" to represent the keyboard screw holes. I'd usually stay away from taking out the screws from the 4 corners of the laptop...
If your keyboard has a trackball there is a mini ribbon that is fragile connected underneath, so after removing the keyboard screws be careful not to pull farther then the slack allows.
If you're lucky you won't have to monkey with any of this and the forward button panel will just pop out. Laptop designers are making it easier to "replace" laptop screens and keyboards because it is a common problem. I'm positive if you're able to secure that connector you won't have that "frosting" effect you see now.
If you have anymore questions just let me know...
Nov 27, 2008 | HP Compaq nx9010
Benq w5000 green horizontal line flickering at bottom of screen
Hi there
This is normally only one of two things : Cable or Mainboard
The W5000 is quite a new Projector and should still be under warranty.
But try changing the cabling first and if the problem still persists , let BenQ replace the Mainboard.
Aug 30, 2008 | Televison & Video
Windows Looks Faded
normally, this indicates that the color settings in Display properties are set to a lower than normal setting
It should be 32 bit true color
Jul 27, 2008 | Microsoft Computers & Internet
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Motorola Mobility RAZR V3 Logo
263 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
