Question about Danby Heating & Cooling
Danby PORTABLE Air Conditioner model DPAC10071 is leaking water from bottom base. The unit is 2 weeks old.
  • THEO81 Jun 29, 2008
    the A/C is not draining properly into the external tank...it seems the internal tank just fills up and starts leaking at the bottom of the machine and all over my floor and when I move or tilt the machine. It is supposed to shut off automatically if internally it overflows but it does not. There is no access to the internal pan, so how am I supposed to drain it and WHY?
    Why do I have to have a hose at the bottom to drain, and where do I drain it to if it is in my house? Unless this machine is malfunctioning there seems to be a serious design flaw.
    Any further suggestions?
Excellent!
Thank you!
Posted on Jun 27, 2008
    Novelist:
    Champion:
  • 230 Answers
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
  • Don Berry Jun 30, 2008
    I am not very familiar with this particular brand. However, the reason for a drain hose is to eliminate the need to manually dump the drain pan. Where you drain it is up to you. If there is a floor drain or other convenient location, you can run the line there. If this is not a possibility then you must manually remove and dump the pan. Depending on the humidity level in your home, it may need to be dumped any where from 2 to 24 hours. I would suggest reading the directions for the removal of the drain pan(s).
    If you are already running a drain line and the unit is still overflowing, I would suggest that there may be a rubber plug in the drain pan. These are sometimes installed from the manufacturer to protect the unit during shipping.
    Obviously you want to make sure the unit is sitting level as well.
Need to fix leaking on my simplicity portable air conditioner 6077 and how the drain works
If it is water in a thru window installation you will need to tilt the unit up a little so the condensate water drips outside. I hope this helps! Thank you and please leave feedback.
Jul 11, 2016 | Heating & Cooling
Water leaking from beneath unit. Some water enter buckets some leaking onto floor. Can't use the unit it leaks so much.
Look for the drain tube which sends the water to the buckets. It may be disconnected or misaligned allowing the water to go the wrong way. The tube can also be stopped up. Blow through it to clear.
Jul 22, 2011 | Danby Portable Air Conditioner
Model DPAC10071 everything lights up but nothing will kick in
Rick, if the water collection tank(s) are full, the unit will not turn ON, until they are drained.
Also, you may not have the temperatures set low enough for the unit to turn ON.
On a more technical side, Current leaking or pressing test button on LCDI Plug.
Remember to press the Reset Button after resolving the technical side issue.
Hope this helps you to troubleshoot and solve the problem.
Jul 09, 2011 | Danby Heating & Cooling
Danby DPAC9008 portable airconditioner: Direct Drain plugs at bottom of unit; no drain nearby. What to do? Is using a bucket the only solution available for this unit?
Your model should have come with a plastic, low sided drain pan, that comfortably fitted under the drain hole. Any low sided plastic container will work. It must have the capacity to hold at least 1& 1/2 cups of water or more.
Hope this helped you.
Jun 19, 2011 | Danby Heating & Cooling
Water light on where do you drain the water out of con.
Most Portables have a small drain tube at the back lower portion of the unit, sometimes there tucked away, so just inspect the area towards the bottom and back of the unit and look for a little tube, sometimes there is a cap on the end that you simply pull off and drain the excess water out of the unit.
Good Luck!
Nov 14, 2009 | Danby Portable Air Conditioner
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Air Conditioner 3 in 1 danby SPAC12030 leaking water on the floor. No water in right side compartiment also no water in the back reservoir. Water leak from right side of the machine. From the right side...
I had that problem last year. When I took it apart I found that the drainage hoses that lead to the reservoirs were plugged with dust build up. I clean out the hoses as well as the rest of the insides. I have since placed the entire unit inside a shallow (under bed) style rubermaid tote and have not had any more water leaking. Hope that helps you.
Aug 04, 2008 | Danby Heating & Cooling
Heating & Cooling Logo
1,322 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
