Question about Garmin StreetPilot c550 GPS Receiver
Garmin streetpilot unable to find sattilites for first 30 minutes of use
My garmin streetpilot takes 30 minutes or so to locate sattilite signals.
then it works fine, unless it`s turned off. then it takes another 15 minutes to locate a signal and start working. each time it goes through the are you
inside a building, is it in n.y. state, and the date. any idea???
  • jonniekaye Jun 27, 2008
    no it`s not new. it just started a couple of days ago.
    i looked for the reset button, but couldn`t find it.
    my garmin had been off for 3 weeks and the onboard battery had depleted,
    could
  • 4,889 Answers
As you have pointed out i believe the depleted on board battery can be the cause of this problem try replacing it. Then try the reset procedure as AvioriX has suggested. If nothing works then you should try a Firmware update.. Let me know how it went so that i can guide you through the frimware update if required..
Posted on Jun 30, 2008
  • 689 Answers
Firs of all make sure your software is up to date. Reset can be remedy to set the values to factory default. however user settings will be erased so after reset you may need to key and some user preferences. Here is the exact procedure for reset
If you need further assistance please post. After issue resolved please rate accordingly to serve you better.
Good Luck
Posted on Jun 28, 2008
    Master:
  • 638 Answers
In order for your GPS to calculate its own location, it needs to receive data reports from four or more GPS satellites. This process is normally pretty fast and will typically take approximately two minutes. However, this assumes that the GPS has a clear view of the sky.
Obstructions such as tall buildings, trees and local terrain such as mountains and hills can affect your receiver's ability to "see" the sky. This is also true of GPS's used indoors or inside of a vehicle. A GPS receiver without a clear view of the sky can take a long time to get a fix on its own location.
The process can also take additional time if the GPS has been powered off for an extended period of time
Attached an external antenna The antenna has to go at the back not in the front.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 27, 2008
  • 3,037 Answers
Did you just buy this or did this problem just start happening? There should be a reset button under the plastic the is around the screen. If this is brand new, it isn't normal and the device is at fault and should be returned for a different one. Let me know you specific situation and let me know of any further information or questions that you may have
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    taking off the front panel revealed no reset button? It would be on the right side
    President:
  • 357 Answers
I would recommend that you reset your GPS (This might help)
There are three forms of resets on the unit.
The first is the reset under the front face plate. The second is where you hold the power button for a long time (30 seconds).
The last and potentially warranty voiding solution is to pull off the front face plate. Remove the four tiny philips head screws. The front face plate can now be lifted off. There you will see a battery and a little connector with 2 or 3 wires attached to it. Disconnect it. Wait a while... 30 seconds.... 30 minutes... overnight.... and plug it back in.
I've read some reports about the web updater software flaking out, so I recommend flashing through the SD card slot if possible.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • Dustin Ellse
    Dustin Ellse Jun 27, 2008
    I have also done a bit more research and have found a possible reason for why the GPS is taking so long to find a satellite.
    TTFF (Time to First Fix) is normally less than a few seconds if the GPS
    system is used frequently. Cold boot, or when a unit has been unused
    for a few days, or moved more than a few hundred miles from the last
    location that the unit was used, the GPS may take longer to acquire GPS
    satellite signal (because the satellites have moved since the GPS was
    last on, and it needs to re-acquire them one at a time).
  • Dustin Ellse
    SiRF’s technology boosts GPS sensitivity more than any other GPS
    receiver currently available on the market today. We have tested the
    performance for all three of the GPS units utilizing the SiRF Star III
    GPS receiver, and were pleasantly surprised how sensitive and accurate
    they were, even in marginal GPS signal locations, such as under bridges
    and in dense urban environments. Thanks to SiRF, GPS reception is no
    longer as extreme an issue as it was only a few short years ago. Prior
    to SiRF’s Star III chipset, it was not uncommon for it to take as much
    as 10 minutes for a GPS unit to acquire a signal. And that signal would
    be lost as soon as line-of-sight to the sky was unavailable.
My Garmin 205W has been working perfect for about a year and all of a sudden cannot find any satellites to navigate on. I reset the unit to factory defaults (and yes.. lost all my "favorites")...
connect this to your computer and run a erro scan, go to computer connect the gps and run the scan, it will show up in my computer. Also do a virus scan, also you need to download the most recent GPS sattilite fix down to your unit.
Mar 31, 2011 | GPS
When i open garmin 12xl it gev me vois when i press page bottom this message show me (Memory Battery is Low ) how to solve this
The memory battery is a BTR2032 or a CR2032. This is one of those coin type batteries. To replace it you need to open the case and depending on when your unit was made you will either find a battery hold or the battery will have wires soldered to it.
The batteries are cheap. Usually under $1. Getting someone to change might cost a bit. If this battery goes out then your unit will forget settings and so on and have to reload everything from scratch every time you use it. It will work fine but might take 5-10 minutes (depends on how many sattilites it can see) to get running.
Oct 10, 2010 | Garmin GPS 12XL GPS Receiver
Will not activate with sattilite and will not stay in time
You just need to reset it. I have a 315 and if I don't use it for a while it forgets where it is and what time. So you need to put new batteries in it, reset it and then let it run outside where it can easily see the sattelites. This forces it to download the sattilite catalouge or data and resynch the time. After that it should be working normally again. This can take anywhere from 5-50 minutes which is why you need good batteries.
If you don't have your user manual you can get one free from magellan Here's the direct link to the pdf version.
http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
The reset is the same as what they call initilization. Thats on Page 4 or (pdf # 12). It's easier to follow what they have then what I can type here as there are about a dozen buttons you need to push. It only takes a minute to do but you have to follow the sequence to get it to reset.
If you don't use any gps for extended periods then they will all need to be reset and resynched to work properlly again. This is just due to the accuracy of the timing and sattelites positions. Thats for any brand or model.
Sep 23, 2010 | Magellan GPS 310 GPS Receiver
Tv not reading dvd or sattilite. jist says unusable signal
There is a fuse on the main pcb under the removable metal cover that will open up due to poor design. It is a tiny little pico fuse beside the big ribbon cable from the audio board. It is usually green with an "F" mark on it. The location is 1C33. Thanks for using fixya.
Feb 06, 2010 | RCA L37WD250 37 in. LCD HDTV
I have a Nuvi 200 and it has worked great until a month ago when it stopped telling where to go. It will not acquire sattilites and if by chance it does it loses them within a minute. I tried to press the...
hold the button between the arrows while turnng on device.
in mantence menu select gps menu --> perform gps cold start
press the middle button the one with 3 lines twice the switch off
go outside and switch on again satalites will start appearing
Oct 25, 2009 | Garmin nuvi 200W GPS Receiver
Garmin c330 has problem finding gps signal and tracking sattilite.
power off the unit first then power on then go to map screen then tap the signal icon bar then wait for your unit to track signal then when you see 5 signal go back to the map screen and check the signal icon and then if there is a firmware update for your unit try to download it.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
No signal
You will have to leave the unit out in the open so it can 'see' the satellites. It might need from 20-30 minutes to acclimatize itself to the new location. It is set at Kansas because that's where the manufacturer is, so that is the last recorded satellite signal.
Apr 16, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
