Question about Toshiba Satellite 1410-S173 Notebook
Power up problem
When you plug the dc power supply in the left most light comes on (green) and the battery light comes on as a sick yellow color. If you leave it sitting like this for a period of time the battery light turns to green. Now when you push the power button the battery light goes out and the external power light goes to a yellowish color and starts blinking. You have to pull the battery out to reset the machine. The owner said that the unit had a problem turning on a few
times before but after pulling the battery and doing it again it would work.
Now it will not power up at all. Can you run this unit without the battery installed in the unit?
Toshiba Satellite 1410-s173 with additional 256mb of ram
Chuck Sayers
Harrisburg Pa
    Problem Solver:
  • 9 Answers
It has nothing to do with the ram, it is the issue of the adapter or battery for toshiba laptop, if the output volatge form the adapter is not steady, the light will get yellow and blink,try it on another toshiba laptop. if it is normal, u should test the toshiba laptop battery by the multimeter, connect the electroprobes wiht the anode and cathode, if the pointer does not fixed in a short time ,the battery is the issue. change it for a new one.
Posted on Jan 10, 2009
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Power laptop fujitsu st4110
Could be a bad battery, a/c adapter or DC jack on the laptop.
Remove the battery and plug in the A/C and try to power on. If it comes on try to gently wiggle the plug where it meets the laptop. If it stays on then it's most likely a bad battery. If it shuts off when you wiggle it then the dc jack is bad. If none of these. Try gently wiggling the plug and tapping the power. If you get nothing at all it's probably the a/c adapter. If it comes on briefly then it's the dc jack
Jul 05, 2013 | Computers & Internet
Not start the OS
This is the Notebook PC category.
Posting, "....and the VoltageS are correctly on the power supply.....makes me think we are talking about a Desktop PC here.
3.3 Volts
5 Volts
12 Volts (All DC)
Green color LED (Light Emitting Diode) referred to, is the motherboard power LED.
All the power cables from the Power Supply, plugged into the motherboard?
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Or;
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
And;
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Or;
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
What are the voltages of the SMPS?
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Post back in a Comment as to the computer manufacturer name, and model number. (Plus questions I asked)
Found on the back for a desktop computer, usually next to the Windows product key; or up on the side of the computer tower (Case)
I have seen some models (Dell) that there is a small front door you open, and the model number is down towards the bottom, on the inside. (Of computer, not door)
While I wait for your reply, in the meantime unplug the power cable to the optical drive (CD/DVD drive), and the harddrive.
Remove the Ram Memory.
Plug the computer back into power. Motherboard LED light on?
We are removing some devices that require power, to see if the motherboard LED power light comes on.
Hold the phone..............or are you referencing to the Green LED light that is on the back of the Power Supply?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=432786
Scroll down a little to the photo. That Green LED light?
Regards,
joecoolvette
Dec 17, 2012 | Computers & Internet
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
May 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
IBM ThinkPad R40
The battery indicator showing a yellow or orange indicates that the battery life is over. You may have to purchase a new battery.
Regarding the place where you can find information about these is that it is universal that the orange indicator means the battery is faulty.
Sep 13, 2009 | IBM ThinkPad T40 2373 Notebook
My Dell Inspiron laptop won't power up. There are no lights AT ALL. It worked when I left for holiday. I have bought a new AC/DC power unit: just the same. The green light comes on when I plug the AC/DC...
If the light on the A/C adapter "goes out" when you connect it to the Laptop... then your motherboard is bad.
Your motherboard is "shorting out" the A/C adapter, in which case you will need a new motherboard.
Sorry....
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Battery light yellow won't come
allow battery to complete charge (green lite)
Or change battery if chrge not completing.
(check your AC charger)
Jan 11, 2009 | IBM ThinkPad T30 2366 Notebook
Will not power up
If the a/c adaptor is plugged into a power strip, reset power strip by turning off and on. If there's no power on strip use another power outlet.
Make sure PC power supply is good and securely connected.
Jan 02, 2009 | Gateway MT6705 Notebook
Acer aspire 3004 WLCi won't power on
Often times when laptop won't power on, it's jack on the back where the power supply plugs in. It needs to be disassembled, soldered back together and that should fix it. Good luck!
Aug 22, 2008 | Computers & Internet
Toshiba Satellite 1410-S173 Notebook Logo
282 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
