Question about Goodman CLQ36AR49 Air Conditioner
Condensing unit while weed eating the yard i accidently got the airconditioning unit wire wrapped around the weed eater. The unit immediately shut off. There is no visible cut or damage to the copper wire, but it did cut through the plastic surrounding the wire. Can someone please tell me what i might be able to do to try and get the unit to come back on. once again it doesnt seem to have any damage to the wire. I flipped the breaker off and back on and reset the thermostate... please help!
    Champion:
  • 254 Answers
Probably one of the wires going to the control board or contactor has been pulled off when this happened. If you feel comfortable trying to reconnect these comment me back and I will try to walk you through it. PLEASE REMEMBER THAT THE CONDENSER HAS HIGH VOLTAGE INSIDE OF IT.
Posted on Jul 06, 2008
Pull on cord for weed eater y 28 yard machine hard to pull how do i repair it
Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
Sep 23, 2012 | Garden
Weed eater made a noise then just quit working, pull cord wont engage
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Jan 23, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
My two year old featherlite weed eater head stops spinning while I am using it. I started a few months ago and would happen randomly halfway through weed eating my yard sometimes, and then it kept doing...
It could be the spool connection or maybe a bad spline engagement, anyhow go to( jacks small engines.com ) and scroll down to your machine under Poulan/weedeater and look up your model they have just about every model you can think of. There you can see the make up of your particular unit and try to resolve your problem.Good Luck...
Aug 16, 2011 | Garden
My unit stays on even after shutting it off or turning it down. I replaced the thermastat and the problem still acurres. HELP!
have you used the weed eater out by the condensing unit could be short in thermostat control wiring to outside unit or a stuck contactor in condenser control circuit try these first then if not there in furnace control circuit at board that jockeys between air and heat remove thermostat wires from board remember thier location bet it stops.
May 12, 2010 | Bryant Heating & Cooling
Weedeater starts and immediately shuts off. I checked the fuel filter and replaced the plug the unit is 1 year old.
Change gas, and spray out carb passages. If you tampered with the mix screws then its a whole nother story!
May 05, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
5 amp fuse in central Airconditioning unit keeps blowing, I keep replacing, somtime is good for long time and sometime for really less than a day
You have an intermitent short in your low voltage wires. You need to trace the wire all the way to the A/H and then to the condensing unit. I bet you will find a bare spot. Check where the wire goes through the brick to the condensing unit. Ground squirrels are bad about chewing though the insulation. if this is where the short is, replace the wire from the A/H to condensing unit.
Nov 14, 2009 | Bryant 462AJC021BA Air Conditioner
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
White will usually go to white or blue, you can go to your furnace to verify which wire is connect to the common terminal (c)
May 07, 2009 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
