Question about Whirlpool Washing Machines
Softner buildup My daughter's Whirlpool washing machine has softner buildup. She has the agitator in the center. That is where you are to put the softner, but it is a mess. How can we get rid of the buildup?
  • s6116e Jun 28, 2008
    The Whirlpool washer has so much softner build up. I need to know what cleaning product to use to disolve it. Thank you.
  • 246 Answers
Fabric softners are designed to be thich and tacky so they adhere to clothing. Unfortuneately, that also means they are going to do it even worse in an agitator expecially as there is no water to dilute it. When I clean my fabric softner cup, I generally just throw it in the dishwasher and let it run since there are many areas of it that cannot be disassembled. Please make sure to run it in a cycle all by itself without any dishes. Now as to the removal. There are two main types of dispensers whirlpool has used. The first will have a greenish blue ring around it. Simply lift up on the ring and it will pull off easily. Now the second style is a bit more chalenging. While the cap up top will come off just by rocking it back and forth. Once this is off you will find a cup underneath that sits on 4 "pins" To get the bottom peice off, place one hand on the top part of your agitator and use one hand to twist the base of the fabric softner in a counter-clockwise direction. It will allow it to come off. Once you it off, you will be able to see down inside your agitator. There will be more build up underneath. I would recommend wiping this part out making sure to clean the drain holes that go out to the side. If you attempt to remove the clear cap underneath, it is very difficult to get the seal on it to seat back in properly. To help prevent against future build ups, pre-diluting your fabric softner with water ahead of time will slow the build up.
Posted on Jun 27, 2008
  • Toby Norton
    Toby Norton Jun 28, 2008
    I'm sorry I have no further definative information for you. I have never had a request for a chemical cleaner for fabric softner. In the nearly 5 years I have been working on washers, I have met with manufactures and discussed these problems (fabric softner build up) durring thier factory training. These were the recommendations for cleaning that they provided. I have always had sucess using the above procedures myself as have the other individuals I have given the procedure to both in thier homes an on this site. However, I am the first to admit, there is always something new to be learned. I would re-post your question as new to afford some of the other readers and techs to have a shot at it. Otherwise my best guess would be using an all purpose cleaner (409 or Fantastic) and doing a lot of wiping and scrubbing.
My ultimate care II washer does not have a fabric softener dispenser, is this a manufacturers defect?
are u sure its not just the cap to place fabric softner is missing? possibly in the center of agitator
Sep 05, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Fabric softner cap keeps coming off during cycle
Push the fabric softener cup down and turn it to lock it into place
Dec 28, 2013 | GE WBSR3140DW Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
How can I remove the agitator to clean the liquid softner dispenser, it is clogged
you will have to remove plastic nut at top of aggitator to be able to raise the aggitator out of the tub hope this helps
Feb 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you get the agitator to come out the fabric softner dispenser is filthy and all needs to be cleaned
By grasping just the fabric softner dispenser and wiggling it from side to side while pulling up the softner dispenser will come out to be cleaned.
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I take a whirlpool agitator apart?
remove the softner dispenser. There will be a cap inside that pulls out. There will be a 1/2 inch bolt to remove. The agitator should pull off now. I put it on the floor and hld down with my feet and pull the sections apart.
Eric
Nov 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I need to remove the agitator due to something being spun around it and it will not spin; How do I remove it?
Pop the fabric softner dispenser off the top of the agitator, pull the round plastic piece in the agitator out, the you will see a bolt through the center, remove the bolt and the agitator will slide out
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
CLEAN SOFTNER DISPENSER
It snaps in. No need to clean it as it cover the agitator cams or dogs.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
AGITATOR DOESN'T WORK WELL
sounds like the spline is stripped on the agitator take the bolt out of the center of the agitator remove the agitator and visually inspect the splines let me know if this works
Sep 12, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
241 people viewed this question
Dan Webster
Dan Webster
Sal De
