Question about Dishwashers
GE Triton XL dishwasher makes high-pitched noise after a power outage and no buttons work. I reset the breaker and pressed the reset tab in top of the door.
  • skirtich Oct 15, 2008
    none of the buttons work no lights and it is making a high pitch sound
  • chadsher Mar 08, 2009
    Same problem, a power outage and it makes a high pitched noise no button work.  Have to keep the breaker off to stop the noise it won't stop.
SOURCE: ge triton xl dishwasher
will not drain
Posted on Dec 26, 2007
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
  • 2651 Answers
debris caught iside pump assy is what it sounds like
SOURCE: GE Triton XL Dishwasher
My Triton XL soap dispenser still has a clump of soap after the cycle has finished. My glasses are left with a cloudy film, and my silverware is left marked with film on it. I have cut down on the amount of detergent, and have not overfilled. I have also tried using white vinegar as the manual states. Any suggestions? Thank you
Posted on Sep 13, 2008
  • 111 Answers
Best way is to call GE Part at 1-800-626-2002 or go online to
Posted on Dec 20, 2008
GE triton xl dishwasher will not drain
First thing is to remove the power. Let it reset and then power it back on. That may mean shutting off a breaker if it is under the counter. When you power it back on, listen for the pump to come on. Also there should be a service technicians sheet under the front kick panel that lists all the troubleshooting steps.
Apr 01, 2015 | GE Dishwashers
I have a GE Triton Eterna EDW30000G Series and the lock button will not shut off, how do i reset it?
Likely it is stuck Mid-Cycle. Try disconnecting power to it by throwing it's circuit breaker off for 20 minutes or so.
Dec 29, 2014 | GE Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
How do you reset the "Lock" cycle in a Triton GE dishwasher.
You press the" heated dry" button for three secs. and then release it, that should unlock it.
Jul 13, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Power outage occurred. Upon power back on Dishwasher has high pitch tone and no lights and it will not do anything but make sound.
A power surge has occurred unfortunately. this surge has fried the control module and, you will need to replace this module asap.
I would check the motor as well. it may have took a hit as well. test the continuity of the element as well.
Jun 02, 2009 | GE 24 in. PDW8800J Built-In Dishwasher
Dishwasher won't stop washing
Could be a couple things... but let's address the "not draining" first
Have you recently installed a new disposal? Ensure that the drain plug is removed "punched-out". The plug is located where the air-gap or your dishwasher drain-line is directly connected to the disposal.
This can possibly make the rest of the machine malfunction due to the sensing of "sitting" water that is not draining. Ensure you're pump and filter is not clogged from debris (Inside, right, rear of dishwasher or screen type material)
Other than that, the problem can also possibly be your control board ($100+ dollars for part only)
Jan 25, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl dishwasher
The part you need is a WD13X10008 from GE Parts 800-626-2002 or order online at GE Consumer Service web site here
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton
Power outage was the culprit for me as well. Resetting the breaker fixed it immediately. YAY!!
Nov 17, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
249 people viewed this question
Top Dishwashers Experts
