1. Detach the hose and turn on. If it runs, place hand over opening. If it shuts off, the control valve assembly is dirty or worn out and needs cleaned/replaced. This is a job that should be done by an authorized Aerus Electrolux service tech. It's most commonly caused by use of "made-to-fit Electrolux" bags, rather than the genuine bags made by Home Solutions.
2. If the vacuum keeps running after detaching hose and placing hand over in port, then check the hose. Drop a coin or similar small item through the hose. If it doesn't go through, there's a clog. It will probably be at the bend of the handle. Plug hose into exhaust port and turn vacuum on. Make sure the other end of the hose is in a bag to catch the dirt and stuff coming out. If you have problems, it's easily removed by a service tech.
