Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore coldspot #59597993
My freezer and fridge stop running cold but the lights and it still sounds like its running fine..
  • choocorc Jun 28, 2008
    THANKS for tyour response, i have a more question. If vents are cleaned out and the compressor hot, when you say running exactly what do you mean? Also, if the compresor is hot and running and the fridge is still not cold then what. Thanks for your help
  • almost there Jun 28, 2008
    refrigerator lights are on, sounds as if the motor is running, but the refrigerator nor the freezer is getting cold
  • 828 Answers
Check the condenser where heat is removed from the system. Look under the front behind the toe plate under the door. Use a vacuum crevasse tool to get into the narrow places to draw out the dust and lint. Make sure the fan under the refrigerator is running. You can remove the bottom panel in back to observe the fan operation. Listen for sounds at the back like a hum and a click. Check the compressor to see if it is hot and running. If the compressor is cold you may have a control problem.
Posted on Jun 27, 2008
  • James Helmer
    James Helmer Jun 28, 2008
    If the compressor is running, meaning it is working pumping gas in the system. Check the freezer for signs of frost, possible frozen up cooling coil would stop circulating the cold air. In this case your compressor is doing its job but the defrost system is not working. Defrost system is made up of a timer, defrost heater, and defrost thermostat.
I have a kenmore coldspot side by side. the refrigerator part is not staying cold. there is condensation inside. the freezer seems to be running fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 27, 2011 | Kenmore Refrigerators
Freezer fine refrig not very cold kenmore coldspot 71984100
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 19, 2010 | Refrigerators
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
271 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
