Question about Zonet ZSR0104CP (zsr0104cp) Router
Zonet router not working with cp and xbox
My new zonet zsr0104cp does not make it possible for cp and xbox for xbox live purpose to work at same time while hooked up to router. There must be a setup process i need help with
I went to zonet support, thanks!
Posted on Jun 27, 2008
I cant setup my zonet router because i lost the installation cd
Type 192.168.0.0.1 into your web browser to configure your router. Or check devices and right-click your router and click view device webpage
Jan 15, 2011 | Zonet ZSR0104CP (zsr0104cp) Router
I just bought a the Zonet ZSR4134WE wireless router to help my Xbox live. After setting everything up my nat type for the xbox live was strict. i was going to try and open ports 80 88 3074 and 53 but im...
Xbox settings have a setting for automatic. This is the best setting because you don't have to enter anything. It is all automatic.
On the router, make sure Nat type says open.
Jul 19, 2010 | Zonet ZSR4134WE Wireless Router
Router says limited connectivity
Not a lot of info to go on, but I'll give you my thoughts on it. In my experience, limited connectivity indicates the modem isn't connecting up to the internet. You can reset the modem by unpowering it for a few seconds, then seeing if it will connect, but I'm sure you've already tried that. Could be a faulty modem, but I doubt it. Chances are there's a software incompatibility issue between the modem and the wireless card. Was the zonet working with the card before? If it was, you might have to go into Network in control panel and delete the linksys connection, and have windows redetect the Zonet. Sorry, all I can think of, not a whole lot of experience in this arena, and my routers always worked. Maybe someone will have had the same problem and know the solution, that would be the easiest way to go, of course.
Mar 25, 2010 | Zonet ZSR0104CP (zsr0104cp) Router
With Zonet ZSR0104CP can't see internet
If the router is connected to the internet then you just have to setup a new internet connection from Network Connections. Select the option for new internet connection. From there read carefully all the options before selecting. And even if you go wrong anywhere, you can come BACK and correct yourself. Select the Router and then give the ID and Password and you will be through.
Nov 02, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
What is default username and password?
Try admin as the user and administrator as the password. These are case sensitive. If they don't work in that order reverse them and try them and even go all capital letters.
Sep 25, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Need Clear instructions on Port Forwarding
This page will guide you. Just choose the appropriate program for which you want the port to be forwarded. The link is:
http://portforward.com/english/routers/port_forwarding/Zonet/ZSR0104CP/ZSR0104CPindex.htm
Sep 01, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Can not connect to network folders at work
This problem is common if your password has expired. If you suspect that this may be true you can contact your network administrator for help or you can simply change your password and restart and see if you've gained network connectivity.
Jul 19, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Can't see both computers in my network places with zonet router
U can give the sharing to one of the folders in the PC1 and search the file in the PC2 so that u can transfer the files with the help of network connections
or
The other method is the u can use the PC mover software and transfer the files from one system to other.You can download the s/w from the below link
http://www.freedownloadscenter.com/Utilities/Automation_Utilities/PCmover_Download.html
Regards,
Ayyasam
May 29, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Everytime i connect to the internet some1 else gets diconnected
It's possible that the router is limiting the number of DHCP connections to TWO.  Check under your router setup page and look for "Maximum DHCP Users" and see what it is set to.
Feb 16, 2009 | Zonet ZSR0104CP (zsr0104cp) Router
Problem
point your browser to -> 192.168.10.1
default user and pass is:
user: guest
pass: guest
(i have tried posting this solution 5 times now and it never shows up!)
Dec 01, 2008 | Zonet ZSR0104CP (zsr0104cp) Router
Zonet ZSR0104CP (zsr0104cp) Router Logo
214 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
