Question about Sony Handycam DCR-PC100 Mini DV Digital Camcorder
Problem loading tape
The tape is not loading properly. It is making a grinding sound and on the rare occasions that it does fit it properly, I still end up with an error message which prevents me from operating the camcorder
  • 48 Answers
The tape may be the wrong sort for you particular camera or there could be falty wiring in the display box i suggest that you get a specialist to help this isn't really my cup of tea.
Posted on Jun 30, 2008
Why is my dehumidifier very noisy?
I would guess that some rubber anti-vibration mounts have aged. If so this may allow the cooling fan to move and grate on the fan housing. It is unusual for the hermetic compressor to give trouble but having just said that, on rare occasions the big-end bearing can fail. This would cause a very obvious knocking noise coming from the compressor. Its just a case of carefully opening up the dehumidifier housing and looking to see what is happening. As an aide-memoire one can tape all the screws to a piece of cardboard adding notes as to where they came from. Take care and good luck!
Aug 21, 2014 | Kenmore 54501 Dehumidifier
Hayward super pump won't prime
Priming issues are almost always due to a bad gasket or loose fitting.
  1. Remove the leaf trap lid. Examine the gasket for debris, cuts or folds that might prevent a tight seal.
  2. Remove and examine the winter plugs for proper seal.
  3. Remove, re-tape or putty the threaded fitting directly in from of the pump.
  4. Check all unions, fittings and connections from the skimmer and main drain to the pump.
  5. On rare occasions the impeller may be impacted with debris preventing water flow. Remove the four screws holding the motor to the wet end exposing the impeller and examine it. Hayward impellers are also know to break at the shaft. This will sound like the pump is operating but never pumping water.
  6. If everything looks normal, try pouring water over the entire wet end while priming. This will sometimes allow water to fill a void you missed. The pump will probably loose prime again until the issue is corrected.
Aug 17, 2014 | Pool & Spa
Grinding noise chevy equinox
would check to make sure the brake pad as not split. can do this if not fitted properly.
Dec 18, 2013 | Cars & Trucks
Kenmore elite makes loud grinding noise with larger loads like a comforter. Ok with normal loads
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 29, 2012 | Kenmore Elite HE5t Washer
2007 Chevy Trailblazer - Stabilitrack light flashes 4-5 times while accelerating. Then stays off. Occasionally when braking, it seems as though the ABS system is engaging and there is a loud grinding...
What code #### ? No code indicates replacement of any sensor . Indicates testing be done . Could be a wiring problem , computer etc...
ABS system is engaging and there is a loud grinding sound ????? Wheel hub bearing .
Aug 20, 2017 | Chevrolet TrailBlazer Cars & Trucks
What is the black box above the throttle body, and what does it mean if it's making grinding sounds?
Throttle Position Sensor if it has a single plug that connects to it. If its making grinding sounds the contacts inside may be wearing out. You would notice your idle jump around or it being tricky to start occasionally but sometimes in rare occasions it shows no symptoms until it completely fails. Here is a pic of what the TPS looks like.
Jan 16, 2011 | 1996 Chevrolet Suburban
Both freezer and fridge stopped workin. only the
make sure the overload relay and start ptc are properly connected to the compressor.also check the wiring. if the wiring is good either compressor is no good or you need to replace the over load relay and ptc switch.rare occasions the thermastat switch needs to be replaced.i hope this helps your problem.good luck i would like to here how things went for you
Jan 21, 2010 | Frigidaire Refrigerators
My MP500 has stopped printing black
Two things, usually the printhead is bad and needs replacement, QY6-0059-000, on rare occasions I've seen the purge assembly not cleaning and purging the black properly, and that happens. I would change the printhead first.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
87 ranger bogging problem while stepping on the gas+tranny issue
either a tune-up issue and or a clogged catalytic converter or weak fuel pressure
Sep 28, 2009 | 1987 Ford Ranger
Sony Handycam DCR-PC100 Mini DV Digital Camcorder Logo
60 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
