Question about Dryers
Kenmore gas dryer series 80 not heating up--dryer revolves but no heat--guessing it's the ignitor--can't access-no lower panel to open tomroske@msn.com
    Genius:
  • 1,028 Answers
Small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
Posted on Jun 27, 2008
Kenmore gas dryer 80 series runs but, will not heat. Should I replace the igniter if there is no light seen when lower panel is off and the dryer is running?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore 63942 Dryer
I need help...i have a kenmore 80 series dryer that is not heating up..does it have an ignitor? what can i do to fix it
heatman101
Aug 27, 2011 | Kenmore 74872 Gas Dryer
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
No heat dryer wont stop kenmore 80 seris
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 16, 2010 | Kenmore Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Have a Kenmore Gas Dryer 80 series, model # 110.78842990 that runs but has no heat, have torn everyting apart and cleaned out all the lint, but still no heat.
Burner not lighting/staying lit. Most likely the ignitor.
Check out
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
Dec 08, 2009 | Kenmore Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kenmore 80 series Heating Problem
Most of these issues will need an ohm meter, unless you want to just take a guess.
For Gas dryers.
1. See if the ignitor glows, if not, check the thermal fuse. (if the lint screen is on top, the fuse is accessed behind the back panel, it's small and white, next to the bulkier thermostat. If the lint screen is in the front panel, the thermal fuse is mounted on top of the blower wheel housing, accessed behind the bottom-front or "kick" panel. The fuse should read 0 to .2 ohms at the most, technically is should be zero. If that checks ok, check the ignitor itself, which has a wire harness that connects about 6" from the ignitor. Should be around 50 ohms... a faulty ignitor would read infinite ohms (open).
2. If the ignitor does glow, and you hear a click, but there is no flame, replace the valve coils, (two small cylindrical objects mounted on the valve) Part # 279834. This is assuming your gas is ON.
If Electric, it would not be the fuse, as on electric dryers it is also in the motor circuit, and the dryer would not run at all. Check the heating element, should be around 9-11 ohms. If good, check all thermostats (operating, hi-limit, thermal cutoff). Infinite ohms is bad. Hopefully it's not more complicated than this, or it can get weird..... Hope this helps.
Sep 15, 2008 | Dryers
Dryers Logo
262 people viewed this question
Top Dryers Experts
