Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon MP130 waste ink tank full
  • Anonymous Jul 08, 2008
    how do you actually empty the watse tank rather than re set the sensor and where is it?
    Scholar:
  • 49 Answers
Here you are.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Posted on Jul 03, 2008
canon MP130 - 0.gif Re: CANON WASTE TANK RESET CODES for Canon MP130 by tac (2/15/07 1:52 PM) reply + / - CANON MP130
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will include printer.
2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and advance value equal to zero.
5. select SET Abs- r level (if there is) and also you will establish into zero.
6. you will turn off printer by button POWER.
Posted on Mar 21, 2009
Waste ink tank is full on canon mp130, what can I do?
Hi
Simplest thing is to throw it away and buy a new one. The overflow pads can be purchased from Canon but I installed one set before and believe me it's not worth the time and effort.
Aug 12, 2010 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber full
You need to change the pads or you can reset the waste tank counter. Here is the reset sequence if you choose to do it.
The reset procedure is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
DONE !
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp130 waste ink tank almost full how do I empty it
Hi There
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 25, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Message-the waste ink absorber is almost full on pixma MP130
That is usually Canon's sneaky way of telling you that is nearing time to buy new printer. Used on older machines without chips on cartriges. After "almost full" msg, usually follows "waste ink tank full" after which printer becomes unusable. Solution: Google "waste ink tank full" reset tool and run it, that should do the thing.
Oct 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
At first I was getting the message to check the ink waste and then I got the message the ink waste tank is full and now it reads check printer 5600. what does it mean and what do I do, toss it in the...
Waste ink amount
setting
EEPROM settings)
- At logic board replacement To set the waste ink amount to the
waste ink counter.
None.
Perform in the
service mode.
1min
Oct 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink asborber i almost full... how do I fix
I am providing you with a link that will provide you with everything you could possibly need as the owner of this printer. This link on Canon's Web site will give you access to user guides/manual, driver and software downloads, support, specs for the system and much, much more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
This link will take you directly to the Support & Service tab on the Canon Pixma MP130 page.
(If not, simply click the tab labeled Support & Service).
Type "waste ink absorber" in the text box then click Search.
Click 1. ERROR LCD: WASTE INK NEAR FULL which will result in 4 solutions to this problem:
  • Ink absorber replacement options - mp130
  • Press ON/OFF switch to reset the multifunction device
  • The mp130 may require repair
Try 1 and 2 first. You must click on the solution to view the details.
This should also be helpful in the future event that you may need to download drivers or access the manual to troubleshoot/fix an issue. Drivers and Guides can be downloaded from the Drivers & Software tab.
Hope this helps! Share your experience by rating this solution.
Thanks for using Fixya!
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp130 showing invalid key/set when pressing menu and check printer 5800 waste ink tank full how do i get printer to go
desliga o cabo de energia, segura o resset pressionado e coloca novamente o cabo de energia o menu sera desbloqueado.
Sep 30, 2008 | Canon Office Equipment & Supplies
Waste ink
yeah try this.
Reset Waste Ink
Jun 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
322 people viewed this question
old marine
old marine
Corne Viljoen
