Question about IBM Netfinity 5500 M20 4RY (86624RY) Server
I took out all my my old SCSI drives and put in 4 new ones. Now I can't do anything!
I replaced all of my old SCSI drives and replaced them with used SCSI drives that work. I turn the server on and all the lights on the SCSI disks where flashing a light brown. I ran the IBM ServeRAID Mini Configuration and restored default settings, told it to do this and that, I played around with different choices for about 4 hours. I am fed up and tired. I want to get these new drives working so I can play around with my server and learn some more new things. Someone please help me out! Thanks a million in advance.
Rich
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the SCSI controller detecting the devices at all?
  • 3 Answers
I had the same problem.
There is a cd that came with the server called "IBM RAID Support" that is a must have to reconfigure the hard drives.
It took me a week to find the ISO image.
I will upload the cd via FTP and send you the link.
Posted on Jun 17, 2009
Hello, I have an old Quantum Empire Series
old ?, no relic?
what exact drive, why not stated exactly the drive part number.
then we can talk exact !
what is your goal. state that first.
the bar code on top, see that and above is a number.
like Quantum Empire Series Hard Drive 2100S
that be a SCSI buss, (I have huge experience with them, all evolutions)
so to connect any HDD< one first finds out what buss it is.
SCSI-1 ,2, or IDE, PATA ,or SATA, 3.5" or 2.5" lap size.
we start there,
yes, we can find a SCSI setup or adaptor but it will cost more
that that old drive is worth, about (size never stated) $5
how much do you want to spend on a $5 door stop?
really?
if im wrong, say so but you never gave the P/N of the drive.
or a photo. solving it all.
i can interface anything...
Oct 02, 2013 | Computers & Internet
Trying to find the jumper settings for a Seagate 36G 80PINS SCSI 15K RPM HDD Hard Drive with an apparent part number 8E036JO (all my Google searches say it's a Maxtor), but the one I have is Seagate....
SCSI hard drives and devices have a jumper setting to configure the SCSI ID.
Each SCSI device must have a different ID.
The jumper/s are set for the following positions across 3 pairs of pins
: : : = SCSI ID = 0 no jumpers - usually for the boot hard drive
: : I = SCSI ID = 1
: I : = SCSI ID = 2
: I I = SCSI ID = 3
I : : = SCSI ID = 4
I : I = SCSI ID = 5
I I : = SCSI ID = 6
I I I = SCSI ID = 7
This gives a total of 8 possible SCSI devices on one SCSI controller.
Aug 25, 2011 | Maxtor 8E036JO 36G 80PINS SCSI 15K RPM HDD...
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Jun 14, 2010 | Ricoh 2GB Printer Drive (SCSI-50PIN)...
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
What kind of hard drive do I need for an acer aspire 4315? From what I have found it needs to be 68 pin, is there anything else? I have replaced a few hard drives and this is an easy fix (much easier than...
A hard drive with 68 pins is a wide SCSI-3 hard drive device.
SCSI drives need a SCSI controller (eg in this case an Adaptec SCSI-3 controller) and the SCSI ID of each hard drive can be set from 0 to 7. The ID setting on the hard drive is jumpered by 3 x 2 pin configuration using a binary configuration to get the 8 SCSI ID combinations.
Depending upon the length of the cable and the number of connectors on the cable, it can support quite a number of SCSI hard drives, whereas an IDE cable only supports 2 drives per cable.
Dec 14, 2009 | Acer Computers & Internet
Netfinity 550
Hi
The error message you are receiving "Inquiry command failed Using IBM-PC ServerRaid Host adapter" makes me think you are attaching the tape drive to the ServerRaid Controller, which is only for Hard Disks. There should be a normal SCSI interface for attaching tape drives, etc. It's possible that the ServerRaid card is a PCI (or older) plug in card, and the normal SCSI interface will be on the main motherboard. If you look on the IBM website for the Hardware Maintenance Manual, it should hopefully make things clearer.
The reason you may not be seeing the hard drives in CMOS, is because you will need to use the IBM ServerRaid Utility to view and configure the disks.
Jun 01, 2009 | IBM Netfinity 5500 M20 4RY (86624RY)...
Installed identical replacement STT320000A but won't recognize tape
The STT320000A is IBM version? some IBM version STT320000A will rewind the tape when inserted. But It can recognize the media after rewind. If can't, try to used the cleaning cartridge or change one new media. regards
Jul 20, 2008 | Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE...
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
Ntkrnlpa.exe issue
sorry, wish i could help you out, however i dont have any experience with computers what so ever, try resubmitting your request to one of the other experts i am sure one of them will be able to help you.
Jul 06, 2008 | Computers & Internet
IBM Netfinity 5500 M20 4RY (86624RY) Server Logo
154 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
