Question about Yamaha Audio Players & Recorders
I just bought the yamaha htr 6140 and i am haveing a problem hooking everything up.i getm sound no pic or pic no sound or pic and sound from direct tv hd box and then the dvd player wont have sound or picplease help me
  • 682 Answers
Http://audio.manualsonline.com/regman/exit/ct?url=aHR0cDovL3d3dy55YW1haGEuY2EvYXYvUERGcy9SZWNlaXZlcnMvMjAwOF9Nb2RlbHMvSFRSNjE0MF9NYW51YWwucGRm&idDeviceType=650&idMfg=55&idProduct=569172
Posted on Jun 27, 2008
I have a 6.1 surround sound htr5740 Yamaha can u hook up an equalizer to it? And if so does it have to be Yamaha equalizer or can u use any brand ?
you can hook up any equalizer you prefer
In a professional setting this would go after your signal processing before your amp
A consumer receiver functions as both the signal processor and the amplifier in one. Some receivers have a "tape monitor channel", "preamp in and out or "through".
upload a pic of the back of your receiver
I believe your amp has no tape out or any type of feature that would allow an insert. Upload a pic though to be sure.
If that is that case you would have to put it before the inputs, which unless you only have one, would be complicated.
http://faq.yamaha.com/us/en/article/audio-visual/av-receivers-amps/htr/htr-5540_black__u/1027/2499/How_do_I_hook_up_an_equalizer_to_my_Yamaha_receiver
Feb 25, 2016 | Yamaha Audio Players & Recorders
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
I recently purchased a yamaha YST-FSW100 subwoofer and plugged connected it to my HTR 6140. Subs woulld not work. How will Iknow which devise is not working?
Turn the sub on, then touch the end of the sub lead when you take it out of the back of the amp..it should buzz to show the sub is ok . If the sub is ok then go through the setup on the Yamaha and tell it there is a sub connected in the speaker setup.
Nov 07, 2009 | Yamaha HTR-6140 Receiver
Loose sound when changing channels
If your using HDMI. The HDMI technology in version 1.1 & 1.2 was riddled with problems. Check your owners manual for version.Or, try the Coaxial Digital or optical output from your sat receiver to your Yamaha receiver, go into "GUI" "Menu" not sure which on the HTR series and Lock the audio input to Coaxial or Optical on CBL/SAT. Then Test. If it still has issues, check the settings for Audio on the SAT receiver and make sure they are correct. If you still have a problem, use a standard RCA from the sat receiver to the Yamaha. At this point audio should be rock solid on analog. Look on the back of your DSS receiver for the model # & write it down. Then go into the units menu "SAT" and check it's firmware version for version and date. It may need an update. Go to your Sat's website, Directv or Dishnetwork and go to support, enter model # and look for any updates that may apply. Hope this helps
Jun 11, 2009 | Yamaha HTR-6140 Receiver
Yamaha HTR 5830 sound and no pic? I get sound in both DVD and TV?CBL modes but no picture.
make sure that the yellow video jack is on the tv out on the surround unit and is plugged into the video jack on the tv. You may have to change the input on your tv to Video1 or Video2 to get the pic to come in
Jun 07, 2009 | Yamaha HTR-5830 Receiver
My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main...
Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
Dan
May 12, 2009 | Yamaha HTR-5730 Receiver
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
How to hook up everything!
I have similar equipment.
You should use an audio digital cable to connect the bluray to the Yamaha receiver and another digital audio cable to connect the HD box to the Yamaha receiver.
Hope this helps.
Dec 23, 2008 | Yamaha HTR-5650 Receiver
97 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
