Question about Gateway Computers & Internet
I am unable to use system restore. It goes through the process than an erroe message says, system restore failed. I have the pc set to backup for restoring. What could be blocking this process?
    Problem Solver:
  • 6 Answers
Some registry works
Posted on Jun 27, 2008
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Unable to restore from system backup
Try AOMEI Data Backuper, a free backup and restore software. It can help you restore from the backups.
Dec 16, 2012 | NTI Backup Now EZ
I used Thosibha NTI Backup EZ to take a complete system back up and for some reason i wanted to restore the complete system back up. When i try to restore, it confirma to erase the hard drive and procees...
Repeat process. If you do a full recovery it will format the HDD. If you do a restore it will not format the HDD, only restore to a early date of your choise.
Dec 15, 2012 | Computers & Internet
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
I have a nokia E63 and the problem is that when i send a message it directly goes in the outbox and the gives the message that sending failed...Kindly help..!
Restore to the factory setting. You can find it on your phone setting. The standard code for nokia is 12345. If still not work. Do a hard reset :
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone. So, backup all of your data in phone memory to memory card. Enter *#7370# from standby screen and the standard code for nokia phone is 12345. And then, backup all of your data in memory card to PC and format your memory card.
Good luck.....
Dec 26, 2010 | Nokia E63 Cell Phone
This is a Compaq Presario CQ62. It is 3 months old. The orange Compaq screen pops up but then the computer shuts down after just a few seconds. Have tried it unplugged, plugged in with and without the...
Simple test to determine if it's a hardware or software problem : try to boot in the BIOS. If you can't then it's hardware you should just return it, it's still in the warranty. If you can then Windows is totally corrupted so just reinstall it.
Dec 19, 2010 | Compaq Computers & Internet
I have ran into a problem with my Acer Aspire 7520g. I started the laptop as usual and it started no problem. I then left the room and when i returned the laptop was switched off. When i now try to boot it...
Ok, you need to boot from your DVD with a Widows, install boot disc, inserted, and boot up on that DVD, then do a startup repair. OR... Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 22, 2010 | Computers & Internet
How do I restore factory settings on my dell inspiron mini 1012?
  1. Restoring a Dell System Running Windows XP.
    Turn off and reboot your computer. When you see the Windows flash screen, depress "CTRL" and "F11". Be sure to press them simultaneously and release them simultaneously.
    Select "Restore" in the "Dell PC to restore by Symantec" window and press "Enter".
    Highlight and select "Confirm" when the message shows that you wiill lose all data if you continue. This will begin the restore process. It usually takes about 10 minutes or so. When it's done, you should receive a message that states the system recovery process was successful.
    Select "Finish" to complete the process and restart your system.
  2. Step 6 Restore a Dell System Running Windows Vista
    Shutdown and restart your computer. Keep pressing "F8" until you see the "Advanced Boot Options" menu. You must depress the keys before the Windows Logo screen appears. If you wait until after the screen appears and then press "F8", it's too late and you'll have to reboot the system and try again.
    Navigate to the "Repair your computer" option
    Select the appropriate language and click "Next".
    Sign onto the system as an administrator. Without administrative privileges, you will be unable to perform the system restore.
    Select "Dell Factory Image Restore" and click "Next".
    Place a check in the check box next to the text that says "Yes, reformat hard drive and restore System Software to factory condition" and click "Next".
    Click "Finish" to complete the process. This will reboot your computer.
May 19, 2010 | Dell Inspiron Mini 1012 Netbook PC
I have a gateway gt4010 with some virus, i reinstalled recovery CD, but it showed "window root" error message w.hal.dll missing... can you to give some tips on this?
Most Gateway systems can be restored to factory settings using the following steps:
Turn on the system and repeatedly tap F11 key (before windows starts to load)
In the System Restore Options dialog box, click Full System Restore (with Backup), and then click Next.
Wait for the recovery process to complete.
Mar 07, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Restoring Files
Is the first of your backup disks a boot-disk?
Often full system backups are restored from a bootable set of disks. There should be a message during startup to press something like F8 to change boot device. You could try using this to see if disk one of your backup is a boot disk & will allow you to restore your files.
Sep 08, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
