Question about Nokia 6300 Cellular Phone
I want my files on the memory card!!
I made a password 4 my memory card & i cant remember it & i dont want to format the memory card coz i need the files on it desperately.. so what shall i do???
plz help,
thnx 4 ur time
    Brigadier General:
  • 7,752 Answers
Sorry you have to reformat the card
Posted on Jun 27, 2008
My Nokia C3 has locked the memory card and i cannot access it. i dont remember setting a password though. What do you suggest i do to unlock it without formatting it?
Locked Memory card.
Note:- Locking of memory card is a RANDOM process.(means it gets locked on its(memory card) "OWN')
1.Whenever a card gets locked,its mainly due to the following reasons.
(I)When you insert it into a uncompatible mode.
(II) when some unsupporte files are placed.
(III)When its for specific mobile.
100% working solution for LOCKED MEMORY CARD is :-
1.Use Unlocker(its like a pendrive device with 9V battery ),and its IC is programmed in such a way that it tests every possile code.
2.The one that sets mades the memory card Unlock.
3.BUT you cant know what the CODE was.
4. Data can NEVER be retraced.
Noye :-Buy an Unlocker available @ Rs.200.But you may not get the same problem often so take it to the retailer it will costaround Rs.20 for unlocking .
Sep 09, 2011 | Nokia C3 Cell Phone
I cant see any photos which are there in memory card in the gallery.
If you cannot see the pictures on your phone, that is on the memory then you need to format it with the steps below but before that connect the memory card to your pc an save all data there first. when finished with the format replace them back to the phone
NOTE: Format the memory card if you forget the memory card password. The device will allow you to format and erase the memory card password without asking for the password during the formatting process.
To format the memory card:
1. Press Menu
2. Select Applications
3. Select Office
4. Select File Mgr.
5. Select Memory Card and press Options
6. Scroll to and select Memory Card Options
7. Scroll to and select Format
8. Select Yes
NOTE: Format the memory card if it intermittently malfunctions (e.g. errors, file corruptions)
The Formatting option will properly configure the memory card for use with the phone.
Dec 05, 2010 | Nokia 5230 Cell Phone
Nokia 2690 memory card password remove
Hi , Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 20, 2010 | Nokia 2690 Cell Phone
My micro SD memory card i cant remove my password. i forget password and in that card i have my important document. i dont want to format it. the another problem is i cant connect it by using card reader....
This Is The Card Error. This Can Be Solved By Inserting The Card In a Mobile And Try The Following Steps:-
  • Go to file manager on your mobile,
  • In the "Settings" option,
  • Choose system folders,
  • In the "System" folder there's a file called "MMCSTORE",
  • Send that to your PC using IR/Bluetooth,
  • Then open it in notepad.
  • The password you need for your memory card is in that file
Sep 19, 2010 | SanDisk 2GB microSD Memory Card
I cannot unlock my block memory card 4 5130 xpress music
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
Jun 02, 2010 | Nokia 5130 Cellular Phone
I locked my 1 gb mmc and now i dont remember the password
hi there,
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password.
please vote me if i had helped.
Aug 17, 2009 | Nokia 5200 Cellular Phone
I forgot my memory card password
keep it in the memory card reader, connect to a virus free system, and format it. If there are any files important in the card, i guess, you can not find them. Try to remember the password at least.
You can retrieve the files using some softwares, if they are not that important, format it and next time you set a password to it, remember.
Aug 17, 2009 | Nokia 3110 Cellular Phone
Password recovery
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Nov 27, 2008 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
My nokia n70
formating memory card wont solve your problem, memory card is just a removable storage device.
Folow these steps to format your phone.
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to mmc memory card.
3. Switch-off your phone.
4. Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
Remember, do not let go all of the keys, hold until you see a formatting word screen show!
5. After a few minutes when the full phone formatting completed, your phone will be back to original system and factory setttings.
If that doesnt work, you need to take it to a service centre for a firmware flash. it is risky to do it on your own, you might destroy your phone
May 23, 2008 | Nokia N70 Cellular Phone
Nokia 6300 Cellular Phone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
