Ruud ac unit
I'm trying to find out how old my ac unit is. ruud model # srk46250-pfb.
  • 828 Answers
Look at the compressor for a date code. Some compressor manufacturers have the date code as part of the serial number. First two digits are for the year and followed a letter for the month of manufacture.
Posted on Jun 27, 2008
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
Cant change valve core cabnet to close c&d remover does not fit high side ruud rheem condensor
I would pump it down to the compressor then change out the valve instead of going through the whole recovery process and make sure the service ports are closed tight
Jul 26, 2012 | Ruud Handler Air Conditioner
What type of run capacitor do I need for a Ruud AC model UPNJ-031JAZ (outside unit)
Looks like it should be a 35/3 370VAC. If it is not legible on the old capacitor read the data plate on the fan motor and compressor. These should say "uf" or "mfd" rating. Good Luck!!
Apr 17, 2017 | Heating & Cooling
My adp coil already failed in my only 2.5 yr. Old Carrier ac unit. I am now looking at an estimated $1500.00 repair. Coil is under warranty so the above cost reflects labor only. Adp serial #7107A07780....
Sorry, I don't have any solution but I'm in the process of replacing my 2 AC systems (4 tons by York). My RUUD dealer has provided RUUD ac and gas furnace with ADP coil and not using RUUD coil. Should I insist on using RUUD coil rather than ADP coil?
Thanks,
Jun 30, 2010 | Heating & Cooling
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
Missing model #
try getting the numbers on top of the compressor and taking that to your ruud dealer
Oct 27, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
