Print problems printer says cover open
  • 1 more comment
  • Anonymous Oct 05, 2008
    printer functions inoperable. says cover open
  • rgiant Dec 21, 2008
    says print fixer cover is open and i need to restart. I have done that several time with no luck. pleae contact me at info@rgiant.com
  • arshad86 Jan 20, 2009
    when switching on printer it says cover open...checked everything in regards to cover...please email me on a.tarmahomed@hotmail.co.uk
When printing in black, every second or third line of print has a blank line through the middle
Posted on Sep 23, 2008
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
Says can't print because top cover open when it's not. Tried resetting by pulling plug, re-opening and closing top cover.
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Feb 12, 2010 | HP DeskJet 5150 InkJet Printer
How do you remove used ink cartridge?the printer is out of black ink
Removing the Print Head / Ink Tanks Instructions to properly remove the print head or ink tanks. Remove the ink tanks before proceeding to remove the print head.
Remove the Ink Tanks
  1. Confirm that the printer is powered on.
  2. Pull open the paper output tray.
  3. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Open the inner cover.
  5. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
Click to return to the top.
  1. Raise the print head lock lever.
  2. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Green power light is flashing for no apparent reason
Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Jan 02, 2010 | HP DeskJet 3940 InkJet Photo Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
DVD label won't print, tray is rejected, 6 orange flashes (cover is supposed to be open)
I've got this printer with no problem.
Make software ready to print with dvd cover closed and press print wait until software tells you to open drawer the place tray up to white arrow's and press print
Should work
Apr 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printer cover open
hi im josh in cebu phils. may i help you?
Friend if the printer states that the printer cover is open. it means that the cover of the printer is open or not locked. the cover above the cartridge is the one mentioned.
1. Be sure to lock or closed the printer cover before printing because if it is open it will not print because the software automatically detect the unclosed part of the printer.
2. check whether the hinges is safely attached it can be found in the printer cover side attached to the body of the printer.
3. try to see if there are some pieces of papers attached or stuck in the cover that's why it detects uncover.
4. clean the cover with soft cloth remove the dust and other dirt.
5. Reboot the pc if the solutions 1-4 is already performed and still warns the problem.
6. Lastly reinstall the printer software CD if the solutions1-5 is already performed and the problem stills occur.
Good luck friend hope i helped you.
Mar 10, 2009 | Lexmark X2250 All-In-One InkJet Printer
Error Code problem
My mother's printer had a similar problem, I was able to find this solution on the HP site.
Disconnect the USB cable from the back of the printer, but leave the printer turned on.
Open the cover of the printer and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the printer and wait for one minute.
Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
I hope this helps you too...
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer will not print
have you been to dells web site
http://support.dell.com/support/index.aspx?c=us&l=en&s=gen&~ck=mn
riz.
Nov 08, 2007 | Dell 922 All-In-One InkJet Printer
399 people viewed this question
jasbo
jasbo
