Question about Toshiba Computers & Internet
My toshiba lap top screen shuts down during use, but you can still hear the drive running and the power light is on
  • porterndel Jun 27, 2008
    The laptop is plugged into the outlet and the power light is still lit up. What happens if a driver goes bad?
  • 77 Answers
Maybe you battery is low.
Posted on Jun 27, 2008
  • HAAi
    HAAi Jun 27, 2008
    what driver are you talking about? what was the last thing that you did before the problem occured?
My computer starts up and then shuts down after seconds what do I do in order to swipe the whole thing out and fix it
This isnt a vehicle question but. If its a lap top then pull the battery and plug it in. If it stays running with no battery then the battery is junk. If it still shuts down then listen for the fan to come on during start up. If you dont hear the fan tbe computer may be getting hot teal fast and shutting down. Take it to a qualified tech to have it replaced before you fry tbe mother board
Nov 06, 2014 | Cars & Trucks
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
Starts up then shuts down within 3-5 seconds
is this happening everytime you start the machine? What is being displayed on the screen? Do you hear the fans running when you press the power button? Do you hear the disc drive running? Do you hear the cd drive click once and the light on the cd drive door come on for a second or two? Is it posting anything on the screen during the boot process? Is it getting to the actual windows desktop which is where you see your icons? Computers shut down for a reason. Either some piece of hardware is not working such as a fan, or some hardware is faulty (such as the memory, cpu or motherboard), or some software issue or a virus has taken over.
Mar 19, 2012 | eMachines Computers & Internet
I won't shut down my laptop
Why is it exactly that you wont shut off your lap top...? I've actually hear that leaving you lap top on constantly is ok for the unit. I myself constantly leave my lap top on all the time and have had no issues with it. Hope this helps Shannon
Mar 07, 2012 | Toshiba Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
Had laptop sitting in lap and turned body briefly lap top went off and will not power up. the fan runs but will not power up. screen is blank
you may have hit the sleep or standby button. Try turning the pc off by holding down the power button untill you hear the fans stop. then power up as usual.
Nov 08, 2009 | Toshiba Satellite M35X-S111 Notebook
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
It's probably a virus. Try doing an emergency scan. If you have Nortan AntiVirus it'll be easier. So try doing that and I hope it helps...
Good luck
Aug 06, 2009 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
Laptop power light is on, wont shut off and screen is blck
You could shut down your by forced shut down. to do this, press and hold the power button for 5 seconds, during which a long beep is heard. The system will shut down.
Try reinstalling the operating system to resolve this problem
May 13, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
