Question about RCA Televison & Video
I purchase an rca hdtv L26HD21 and it has no color
    Genius:
  • RCA Master
  • 1,689 Answers
The first thing to do is to read the user manual. Check to see that the colour control is turned up. There may be a menu control reset that can be activated to zero all the controls to their factory default.
The set may have a multi standard capability, and it is in the wrong standard mode. If an NTSC set is in the PAL mode, or visa-versa, it will not show colour.
Call for warranty service if you cannot resolve the no colour issue.
Jerry G.
Posted on Jun 27, 2008
RCA 52 HDTV Projection color is going in 3 different ways like I'm looking in an hour glass!! Does anyone have an answer???
very easy repair on that model depending on wether the auto convergence option is still listed under the setup menu options. Let me know if its still listed and I will assist you with the issue.
Mar 29, 2012 | RCA HD52W59 HDTV Projection Television
What's your problem?DIY Rca HD50LPW165 50in 720p DLP HDTV Color Wheel
thats the 267888 color wheel which has been discontinued for several years now. However you can get your color wheel rebuilt by contacting the guys at www.tvrepairworld.com
Mar 15, 2012 | RCA Televison & Video
I just purchased this tv. I had no trouble hooking up the satalite cable box but When I hooked up the dvd player the picture is only in black and white. How do I fix this?
Are you using component video (red/blue/green) rca jacks, or composite video input (yellow) rca jack? You need to match the color but watch out and do not get confused with the red and white RCA for audio.
Dec 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Need a color wheel for RCA Scenium HD50LPW165 50 in Rear-
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
http://servicemanuals.vstore.ca/
Oct 16, 2009 | RCA Scenium D40W20 40" Rear Projection...
Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
Jul 15, 2009 | JVC AV-56P575 56" Rear Projection...
Infocus 61 inches DLP-HDTV.
Infocus was always made by RCA for infocus the parts are straight RCA be warned that the parts for the RCA dlp's are very exspensive
Mar 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Whining noise problem and color flickering
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
Jun 18, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA 56" Rear Projection Television
Not sure if you have the same problem I have but my colors are all off too.  I have a 52" projection and from calling RCA with my problem (colors off & have shadows) they said all projection tv's color need to be adjusted every so often (which they do not tell you) after purchasing this tv for $1000.00 13 mos ago I have the same problem.  It will be approx. 500.00 to fix the problem and I got no where with the RCA 800 number.  A friend of mine had the same problem so I am sure its the same.  Good Luck!
Oct 21, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
