Question about Hitachi SuperScan Elite 802 21" CRT Monitor
My moniter is a CM 2111MU
When it is powered up,it only goes as far as invalid sync does not come up all the way
The invalid sync indicates there is no video signal getting to the monitor. Have you checked the connections and video driver card? IF you haven't, you might try a different monitor on the video card to verify that the cabling and card are okay. If both test out as good, the next step would be to remove the cover and check the monitor's connector but that has to be done very carefully with the unit off and given time for voltages to neutralize inside. Even then there might be lethal voltages on capacitors...if you're not experienced, this would be something I'd turn over to someone who is.
Hope this helps.
Posted on Aug 21, 2008
When I sign up for a online metro PC's account it says my email is invalid??? Thats as far as it goes
There is some help here. Underscores and other seldom used characters can flag a bot into thinking your email address is invalid.
Ideally it should be
lettersANDnumbers@provider.com
http://webapps.stackexchange.com/questions/24123/why-is-my-e-mail-address-sometimes-considered-invalid-by-websites
and this Wikipedia goes into more detail.
https://en.wikipedia.org/wiki/Email_address
Nov 18, 2015 | Computers & Internet
HDMI to VGA
You need a video format converter to connect in between.
Apr 30, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Water goes into tub and drains right back out without agitating
Hello, welcome to FixYa. I understand you have a washer, "water goes into tub and right back out", correct ? To address this, and as long as water is indeed entering the unit here`s what I find is most common when dealing with the symptom you`ve described ( as long as water isn't filling over the top...that indicates a different issue ) I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far. If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, ( refer to your manual, but it is typically recommended to be about "48 to "60 in height but not more than 90" or so ) **The standpipe drain requires a minimum diameter standpipe of 2" (5 cm). The minimum carry-away capacity can be no less than 17 gal. (64 L) per minute. A 2" (5 cm) diameter to 1" (2.5 cm) diameter standpipe adapter kit is available. " The top of the standpipe must be at least 39" (99 cm) high and no higher than 96" (244 cm) from the bottom of the washer.** Also if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon. Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there. Thank's for coming to FixYa and good luck. Regards,
Sep 17, 2011 | Washing Machines
Can canon lv-53 projector run on USB....
MSRP (USD) : $1,299 Brightness (Lumens) : 1250 ANSI Contrast (Full On/Off) : 300:1 Variable Iris: No Audible Noise: 32.0 dB Weight: 2.2 kg Size (cm) (HxWxD) : 8 x 28 x 21 Std. Lens: Focus: Manual Zoom: Manual, 1.20:1 Throw Dist (m) : calculator.gif 1.3 - 6.5 Image Size (cm) : 86 - 508 Optional Lenses: No Digital Zoom: No Digital Keystone: Vertical Lens Shift: ** Warranty: 3 Years Performance: H-Sync Range: 15.0 - 80.0kHz V-Sync Range: 50 - 100Hz Compatibility: HDTV: 720p, 1080i, 1035i
575i EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes Display: Type: 1 cm 3 LCD Native: 800x600 Pixels Maximum: 1280x1024 Pixels Aspect Ratio: 4:3 (SVGA) Lamp: Type: 160W UHP Life: ** Quantity: 1 Speakers: Mono Max Power: ** Voltage: 100V - 240V FCC Class: B Special: ** Status: Out of Production First Ship: Nov 2003 Last Ship: Mar 2006
May 08, 2010 | Canon LV-S3 Multimedia Projector
Power supply for a cm 2019 moniter
Here is a link to where you can buy the power supply.
http://www.lcdpayless.com/productpage.php?productId=366.
I hope this will help you.
Happy Computing
Jan 09, 2010 | Balance CM2017 17" Monitor
Moniter shuts down while playing wow while not in windows mode
Go to your computer's Control Panel, Power properties, and change the power scheme to Always On, where hard disk shutdown, monitor turn off and system suspend are all set to "never". This should help.
Dec 26, 2009 | Xerox XA7-17i 17" LCD Monitor
Auto sync appears to not work properly
The projector does not recognise a vista display res. Change the pc to the native res of the projector for best results
May 19, 2009 | BenQ PB8250 Multimedia Projector
Why f257 turns on no picture light blinking?
Sounds like you have a video card issues..Also try turning off Monitor first, then shutdown PC. Then Turn monitor back on first then PC..It should sync up...
May 18, 2009 | Computers & Internet
Hitachi SuperScan Elite 802 21" CRT Monitor Logo
206 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
