Question about Whirlpool GEW9250 Electric Dryer
DUET dRYER 9250
I PUSH THE START BUTTON BUT THE DRYER WILL NOT RUN???
WHAT SHOULD I DO??
  • mbarron Jun 28, 2008
    When I push the start button the drum will not turn and there is a buzzing or more of a humming sound from the motor. It sounds as if the motor is engaging but the drum will not turn...I removed the top cover, exposing the drum and gave it a little help by pushing on the drum to start it. With assistance the drum turns under power of the motor and functions normally. Is it a motor problem?
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If this doesn't help, post me back and I will do some more research to help resolve your issue.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
  • David Emmel
    David Emmel Jun 30, 2008
    Just checking back to see how you are doing and to offer more assistance, if required.
    Thank you,
    Dave E. (Illeagle)
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Dryers
My Whirlpool Duet electric dryer WED9400SW0 dryer turns on but when I push and hold the start button it won't start rotating. It worked fine all weekend and then today, nothing. Help??
heatman101
May 04, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
The dryer won't start, when I push the start button is just beeps. I checked the door and it's shut and nothing is in the way. It was working a few hours ago. We had a bump in the power earlier today...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet 9250 electric dryer taht is about 5 years old. When you go to start a load the status light shows "sensing" after you push the start button (which clicks when you push it) and then...
Hi
Thanks for using FixYa. It seems to be an issue with the belt. Please check this video on how to replace the belt in dryer. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 18, 2010 | Whirlpool GEW9250 Electric Dryer
When i push and hold the start button the timer light flashes but it doesn't start. the interior light stays on even when the door is closed. door switch maybe???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Jan 17, 2010 | Whirlpool Dryers
My whirlpool dryer model- ygew 9250 pwo will not power up when I control on button. If I push the power on button and the pause button at the same time some times it will start and run and sometimes I may...
When this problem occurs are the small lights on very dim? If so I would turn off the power and remove the top off the dryer. Then re-seat the 4 ribbon cables on the display board. Alot of people replace the front panel or control boards when the problem really is the ribbon cables. If the LED's are not lit dim then you may need to replace one of the two boards.
Jul 24, 2009 | Whirlpool GEW9250 Electric Dryer
Duet 9250 dryer. Won't start up. I did bridge
try the door switch. in some models you can jump the wires to see if it starts.hope this works.
Jun 23, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
200 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
